WHICH EDF IS BETTER?
I am deciding between these 2 EDF'S I am not too familiar with them and was wondering if anyone could help me out in deciding which one is most suitable. The person I am buying for is an experienced flyer of both Turbine Jets and EDF's. Any suggestions will be much appreciated. Thank You!
#1-http://www.nitroplanes.com/arttech-21291-f14-rtf.html #2-http://www.nitroplanes.com/69a718-blueangels-rtf-24g.html<br type="_moz" /> |
RE: WHICH EDF IS BETTER?
If your friend has Trubine experience then the only way to go is with the F-14 even though it uses small motors (55mm). The swing wings will give more of a challenge than the F-18 even though it uses a larger motor (70mm). Too, the F-18 is listed as "super size", not much diff. when you compare them side by side. So, for the money and for someone skilled at flying the F14 would be the better choice.
F-14 F-18 ★ Wingspan:1000mm/39.4in • Wing Span : 840mm(33.1 inches) ★ Length:980mm/38.6in • Length: 1200mm(47.2 inches) ★ Weight:1100g/38.8 oz • Flying Weight: 1130g(39.9 oz) |
They both come with fixed gear. Retract gear would be nice, and make a faster plane.
http://www.nitroplanes.com/69a718-jo...-eretract.html |
I wouldnt get either of them since they're both from Nitro Planes spend a little more get a comparable one from your lhs.....you will thank me for it later....if you have to go through one of theses cheap internet company's order from XenonProject at least they answer there phones
F-18
| All times are GMT -8. The time now is 12:15 AM. |
