Replacement ESC for Venom 50mm F86
Need a replacement ESC for my Venom f86 50 mm jet. Comes with 20amp no name system. Which of the Hobbyking ESC will stand up and not cost a lot
Bill PTC |
RE: Replacement ESC for Venom 50mm F86
take a look at tower hobbies SUPER TIGRE LINE OF ESC,
JUAN |
Thanksw
Bill PTC |
Looks like you could be sorted out now but i'll add my two pennies worth in case some one else comes along like i just did. ;)
I'd go for a 25amp Plush ESC from Hobbyking as it's a touch more amp's than you need but won't hurt any,plus there a good ESC with out a doubt because i've been using them for a few years now and mine have all stood the test of time. :D If you don't want to go with 25amp's for any reason the HK Turnigy 20amp ESC is ok too,i've only ever used that one in a couple of planes but it does what it says on the can so no complaints there. |
Thanks. The 25amp sounds good
Bill PTC |
