freewing F 16 Jet front landing Gear
the front gear on this jet just dont like to land in a cut grass runway. the wire bends I would like to know a fix would be to use a stiffer wire and bigger wheels . do you think it will help.
see photo of front wire and cuppling https://cimg5.ibsrv.net/gimg/www.rcu...d7f413207d.jpg fron freewinf f16 wheel |
If it's only 3mm wire I would go up to 5mm, that should hold well with your current issue. Larger wheels would definitely help but look rather silly on the jet.
F16 falcon front wheel fix
Originally Posted by Joseph Frost
(Post 12445494)
