free wing F 16 Jet front FOAM BUILD
HOW CAN I STRENGTHEN THE BOTTOM FOAM DUCT FOR BELLY LANDINGS on grass , I dont like the small from wheel for take off in grass, I have to do something so if I can hand launch [can this model be done ].https://cimg1.ibsrv.net/gimg/www.rcu...ec26aae7e5.jpg
Easy to do, get from your hobby shop some light fiber cloth and lay it over the belly with slow cure epoxy or even water base resin will do. I suggest fit under each wing little ply fin/skid to protect your linkages and avoid possibility of wing tip digging into the ground on landing. I have done hundreds of flights with similar size 64mm "F-16" model by Kyosho back in the old days of brushed motors, bungee launching them , much safer than hand launch, unless you really know what you are doing.
F16 fix for grass landings
Originally Posted by Joseph Frost
(Post 12450802)
https://cimg4.ibsrv.net/gimg/www.rcu...1430ce24ab.jpg
My catapult set up. This might give you little hint, I use on all of my catapult launchers to protect wing tips and servo links. |
