EDF Bungee
Does anyone have some homemade bungee systems out there that they could share with me? Have seen several videos where some use a dolly and some use wooden dowells for launching. Also where can you buy the bungee tubing?
Thanks Voodoo |
RE: EDF Bungee
Here's a nice, easy to build, one.
http://www.rcgroups.com/links/index.php?id=3995 And you can try here for cord. http://store.karstsports.com/bungeecord.html |
RE: EDF Bungee
1 Attachment(s)
Wow ... I have been wondering how to get one up. I killed 2 Micro Jets but I love them, launching has been the problem. Now there is some ray of hope for me.
RE: EDF Bungee
Voodoo,
I had one heck of a time trying to squeeze info out of people when first wanting to build a launcher and sympathize with you! For this reason, I have a couple places to compliment the build that is shown at the “zagi” site. I use a modified version of the Bungee Launcher found at www.yourzagi.com/launcher and I would recommend this one as it is cheap and easy to build. I built my launcher a bit different. Mine was shortened to 48” long and works just fine with the jets I launch, which means it can handle just about anything. It also makes it easier to transport in a car if needed. I also made three types of launch platforms, a Padded Rail, a Launch Ramp and a Low Friction Rail. The Ramp is a piece of 1x12x48” white shelving board I got from Lowes or Home Depot and it works great. The Padded Rail uses the stiff insulation; don’t use the soft rubber type insulation as the wings/fins tend to dig into it. The Low Friction Rail was made from 1” PVC bored to accept the ¾” PVC short tube and coupler. I glued a short piece of ¾” PVC to a coupler, then inserted and glued it into the hole I bored in the 1” Rail…that way there is no interference as the width of the coupler doesn’t exceed the width of the 1” PVC. You can drill a small hole into the ¾ PVC from inside the 1” and use a screw so it definitely won’t come apart when dismantling. Here are some pics and tips: My first launcher, a wood one from old plans- http://www.rocketryforum.com/ctulank...=bungee%2Fwood My PVC Bungee Parts and some assembly- http://www.rocketryforum.com/ctulank...r=bungee%2Fpvc The Bungee Assembled showing different setups and how it hooks up- http://www.rocketryforum.com/ctulank...%2F&startpic=0 The Bungee in use showing new Low Friction Rail(see pics at end)- http://www.rocketryforum.com/ctulank...f4dfirstlaunch Here are some tips: I used Surgical Tubing for my Bungee cord rather than Bungee Use the ½” Surgical Tubing, ¼” diameter center with 1/8” walls You can also use the 7/16” bungee sold by www.hobby-lobby.com Length of the Bungee was 30-33 feet. Use at least 12” long steel nails to secure your launcher Get a fish scale at the store Set tension using the fish scale to 5 times your aircrafts weight. My FA-18 weighed in at 43 oz and the bungee was stretched and tension was set to 19 lbs. My friend had a digital scale and it showed up 15 lbs, so the digital ones do make a difference. Use Quick Links to hook up your system…it makes assembly and takedown easy I lengthened my legs by 5 ½” all the way around on my bungee to get it up off the ground a bit. Do not exceed a 10 degree angle Make sure your launch rails/ramp are in a straight line with the bungee cord FYI, since I wrote this, I have switched pretty much to a foot pedal launch across 25' of carpet runner that acts like a runway...it works great and takes less time to set up. I hope this helps and gets you started on your way to launching. I use mine a ton and keep in the the car at all times these days. Let us know what you come up with and how it worked out. Cya, Carl |
RE: EDF Bungee
Carl,
Nice tips. I really like the launch board set up. Hadn't considered the stress on the alierons. Where do you buy the surgical tubing from? |
RE: EDF Bungee
I get my surgical tubing locally, but there are other places to buy it. I recommend as mentioned the 1/2" diameter with a 1/4" hole and 1/8" wall.
Carl |
RE: EDF Bungee
The cheapest place to buy bungee cord is at most any marine sales place. Its a common item in boating and they should have almost all sizes.
| All times are GMT -8. The time now is 03:44 AM. |
