Ziroli - Tubinator E
I have this plan on my to do list later this winter. Can anyone share with me what type of flying performace they get? Any build reccomendations?
Thanks for your time!! Mark |
RE: Ziroli - Tubinator E
Mark, you will find it to be a very stable , preditable flier. Keep in mind it is not a 3D plane. If you do build it with retracts the weight is going to be a bit high. The other thing that will help this plane out is to keep it as light as possible. It is going to take a fan unit with at least 2 and a half pounds of thrust.
Sounds like building it for a turbine instead of a ducted fan will be better?
