EDF Help
I've been doing some reading up on edf's and found now where saying how to balance the fans. Is there an easy way or is a learn from you mistakes type of thing.
Any help in this would be great |
RE: EDF Help
If you look at the Test Flying section of my [link=http://www.rcuniverse.com/magazine/article_display.cfm?article_id=1031]E-flite F-15 Eagle[/link] review, you will see one way to balance rotors. Using a good balancer like the Dubro Tru-Spin Prop Balancer, you simply sand the blade tips until the rotor no longer favors the blade. You can also dab a small amount of clear nail polish (or spray paint) on the opposite side to add some weight.
Good luck! |
RE: EDF Help
Thanks for that so what your saying is that it would be just like balancing and prop or a set of heli blades then right
RE: EDF Help
Correct.
RE: EDF Help
Ok cool I'm thinking of ordering one for a project I want to do soo thanks for your input on that
RE: EDF Help
| All times are GMT -8. The time now is 08:38 AM. |
