HELP
HI MR SALTO HERE IM A NEW MEMBER TO RCU FROM AUSTRALIA GREAT TO BE HERE!! IVE BEEN DESIGNING AND BUILDING RC AIRCRAFT FOR 3O+ YEARS !!DOES ANYONE NO HOW MUCH STATIC THRUST THE HAOYE EDF 51MM 7 BLADE FAN PUMPS OUT @ MAX 50,000 RPM ALLSO THE HAOYE 64MM 7 BLADE @ 50,000 THANKS GUYS !!!
RE: HELP
Hello I think you need to post the volts and amps because there is math that can ne done to get that info. And may I welcome you to the forum and people think whenyou write in caps you are yelling. Okay Mate I hope you find out I would think with 4 cell battery it is less then 2 Pounds but don't take my word for it, like I said the is a way to figure that out.
RE: HELP
test runs from a while back
haoye 51 mm fan 7 blade LSJS 5000 kv motor(not real sure of the kv) with the "alpha fan extension" 35 amp thunder power esc 3s 2200 and 4s 2200 thunder power 25c packs 3s settled in at 11.08 volts and 22 amps peak amps was 24.5 at startup 4s settled in at 13.5 volts and 29 amps peak amps was 34 at startup did not get an rpm reading. did not attempt to measure thrust. the folks at little screamers, scott or bob, can give ya the actual kv of the motor. a little screamers jet screamer. www.littlescreamers.com didn't test with the wicked motors from donsrc.com would expect similar results, though maybe those numbers will help you find the thrust ballpark you are looking for. mongo |
| All times are GMT -8. The time now is 10:13 AM. |
