RCU Forums
-   Electric RC Jets (https://www.rcuniverse.com/forum/electric-rc-jets-198/)
-   -   Evader EDF (https://www.rcuniverse.com/forum/electric-rc-jets-198/9700356-evader-edf.html)
BalsaBob 04-30-2010 12:08 PM
Evader EDF
Finishing up the new Evader from Great Planes. Wondering if anyone is using the supplied bungee launch setup ? ...... this plane seems to have so much power, that I think it can probably just fly out of your hand with a minimal hand launch effort. Thanks. Bob
bobferguson 04-30-2010 01:23 PM
RE: Evader EDF
From rcgoups re hand launch
http://www.rcgroups.com/forums/showp...9&postcount=12
gp125racer 04-30-2010 06:56 PM
RE: Evader EDF
Havent flown mine yet, but am definately planning on using the bungee for the first few flights.
Don
focusproduct 05-02-2010 08:08 PM
RE: Evader EDF
Keep us posted on how she flies. I just flew my kyosho jet illusion for the first time today and what a joy! Love that little plane!
BalsaBob 05-03-2010 06:17 AM
RE: Evader EDF
Yes, I am going to use the bungee setup. Though this plane has a lot of power ...... it is also fairly heavy (for a plane this size). Bob
BalsaBob 05-16-2010 07:12 PM
RE: Evader EDF
Flew the Evader for the first time today. WOW ! ...... very fast ! Incredible vertical performance ! Fastest (small) EDF I have ever seen. The bungee launch worked great ! ...... its a heavy airplane for its size .... I don't think hand launching it is a great idea. The guidance and information in the manual on flight performance, setup and the use of the bungee launcher, is very accurate.
Bob
Ductedfann 06-04-2010 08:35 PM
RE: Evader EDF
1 Attachment(s)
If your looking for one Ductedfans-rc.com in stock. I use Wemo Micro fan and Mighty Might motor on 2200 4s hand launched
Morris
MinnFlyer 06-17-2010 08:09 AM
RE: Evader EDF
I have been reviewing this Jet for RCU Magazine and I agree that the bungee launcher is far superior to hand launch. And yes... It is FAST!
ww2birds 09-18-2010 03:43 PM
RE: Evader EDF
Went out to fly mine today, but could not.
During the "break in" procedure, all of a sudden at the 3/4 throttle setting a lot of vibration. Stopped to inspect. Looks like the motor shaft is bent. I'll take it apart to be sure. No way it could fly this way, it would shake itself apart.
I was not surprised at the rather crummy looking fan and housing (after all, what can you expect for the price...), wondered how it could hold up at this rpm. Is it too late to retrofit a better motor/fan into the shroud that is already epoxied into the plane?
Dave
ww2birds 09-18-2010 05:21 PM
RE: Evader EDF
More...
Took the airplane apart. Was pleasantly surprised that I was able to pull the HyperFlow unit out (the CA joint to the fiberglass shroud came loose). Just like the guy over on rcgrps, I found the "flange" at the front of the fan housing (that the motor screws to) had melted and allowed the motor to do about 1/4 turn. A very ugly mess. I'd post a pic but just the same as the one over on the other forum.
Also saw some interesting discussions about sanding flash off fan and stator blades, and especially comments about NOT doing what the manual recommends on removing the guide fins inside the motor housing. I found that once these were gone and the bore was smooth, the motor fit quite loosely. I ended up wrapping the opposite (non-drive) end of the motor with some vinyl tape to keep it centered. Perhaps as was speculated on the other site, this tape restricts motor cooling, and causes the melting problem. The advice seems to be to slowy trim down the guide fins with a hobby knife so you get a good fit bit still centered.
I think a good compromise would be to reach past the end of the housing with the dremel sanding drum, remove all the fins to the front housing, leaving maybe 3/8" to 1/2" of guide fin to trim carefully with a hobby knife.
Ugh. I sure would love to find a much nicer fan that is no so much of a kludge... but at least I can repair now...
Dave
