RCU Forums
-   Electric RC Jets (https://www.rcuniverse.com/forum/electric-rc-jets-198/)
-   -   Lets mod the evader (https://www.rcuniverse.com/forum/electric-rc-jets-198/9760520-lets-mod-evader.html)
edgeflyer 05-26-2010 10:53 AM
Lets mod the evader
Flew the evader last weekend and am thouroughly impressed. BUUTTTT it as everything needs a little more speed. not saying its slow cause out of the box its as fast as the video, but i owned a 200 HP kawasaki zx10 and wanted more power. so not being too smart about wattage and motors. I would think a motor upgrade would be best bang for buck, but at what expense to flight times? right now its 3.5 minutes and make your aproach. my timinh on my ice 50 is medium, but the motor is warm enough i can only hold it about 4-5 secound. I know i can optimise flow inside the fuse, but i want a bigger bang than 4 hours of work for 1 MPH. learn me please.
mongo 05-27-2010 12:05 AM
RE: Lets mod the evader
donsrc.com
wicked 4400 special
edgeflyer 05-27-2010 10:28 PM
now that ive cleaned the insides up im at at 37 amps and 580 watts which exceeds their max 50,000 rpm they recomend for the fan. I havent flown it with the ducting though. maybe that'll give it a little boost. I even polished and waxed the glass. nice and slick, and made ducting for it.
skyhawknut 05-27-2010 10:46 PM
So.....Let's see some pics!
MinnFlyer 06-17-2010 08:15 AM
You want this thing to go FASTER???
You're a sick man!
:D
cccdad 09-09-2010 12:40 PM
You using this motor in the hyperflow or are you using a fan from dons also?
ORIGINAL: mongo
donsrc.com
wicked 4400 special
You using th
P51ACE 09-09-2010 02:14 PM
well 580 is good but try 900,that's what mine has init so far,still gotta maiden it though,set-up is a secret though;)
i3dm 09-11-2010 07:39 AM
ORIGINAL: P51ACE
900W out of such a small motor ? [X(]
The only mod i have on my Evader is a rudder - i just had to have it for aerobatics - and i honestly dont know why Electrifly didnt design it with a rudder to begin with !
P51ACE 09-11-2010 01:07 PM
not the electrifly motor,but a a 28mm of a different brand,re maiden today
i3dm 09-11-2010 08:01 PM
how did you fit a 28mm motor in this EDF unit ?
P51ACE 09-11-2010 11:31 PM
nothing is stock in my Evader,Ice 100 esc,s75 digital on ailerons,hs-65 on elevator an custom made 60mm fan with cut down rotor and 28mm motor with custom 80% thrust tube. Flew it today and after trimming her out i'd say an easy 140:)
