CAN i use a 1280 prop for the slow stick
CAN i use a 1280 prop for the slow stick tks im ordering some 1180 props hobby shop just has 1280 and i want to fly this week and tks
My Feedback: (21)
RE: CAN i use a 1280 prop for the slow stick
It depends on the battery you're using mostly. As you put larger and larger props on the motor, it draws more and more current (Amps). If you're using the stock 6-cell 7.2 Volt battery, a 1280 prop won't cause the motor to draw too many Amps. The 7-cell 8.4 Volt battery is borderline; you can get away with it if you keep your full throttle run time to a minimum. Forget about it if you're using the 8-cell 9.6 Volt battery.
ok it was ok i have 7cell battery works good to ill go back to the 1180 when they come in plus i made 2 good landings no broken props today
