Lipo Charger!
MD
Lipo Charger!
Im looking to buy a Lipo Charger! Im looking for something good, but the not the very best! Something in the mid range!
Any Suggestions?
Alex
Any Suggestions?
Alex
My Feedback: (7)
NC
RE: Lipo Charger!
For 1-4 cells check out the E-Tec 2500 (around $55). I've read many good reports about that charger. I have the Kokam 402 which is also nice since it has some automatic functions that help prevent over charging, but is more expensive at around $90. There are others to look at: Hobbico, Worley, etc., that are in the $50-$100 range, but I don't know much about them. Most of the chargers over $100 will give you multiple battery charging options (NiCds, NiMh as well as LiPo).
RE: Lipo Charger!
Something to think about is how many cells you'll be using, and of what capacity. Many of the lower-priced chargers can only charge 2 cells and/or only charge at limited rates (which isn't a problem, as long as you're patient). The Worley MCMR charger available from Balsa Products looks like about as cheap as a fully functional 1-4 cell charger gets. I believe there's also an apache 4 cell charger going for around the same $ now, but I don't recall who sells it. Personally, I bought a Triton for it's versatility/cost ratio. Hate to sound preachy, but if you're new to Li-power, make sure you read the guidelines and adhere to them strongly, lest you send your plane or house up in a pillar of flame[:@]. In other words, use common sense. Hope I helped.
