Wingo Balance?
CT
Wingo Balance?
I have just about completed the assy on my Wingo, and can't decipher from the instructions where the balance points are on the wing...also the control surface hinges call for foam tape (that was not with the kit) so I used pkg tape with a dab of epoxy, will this hold ok? or should I use foam weather stipping tape?..Thanks in advance for any help...
