Hitec CG-335 Charger
RE: Hitec CG-335 Charger
This is the spec info for the CT-335 from www.hitecrcd.com
- Nicad and NiMH capable
- Digital LCD Readout (Volts/Amps)
- DC to DC charging with Booster Circuit
- Delta peak cut off with automatic trickle
- MOS-FET drive control with pulse charging
- Wide Input Voltage range : 9 - 15 Volt
- Input Battery minimum capacity : 10A
- Charging Amperage : Glow ( 1 cell ) : 1.1A
Primary output 4-24 cell: 0.5A - 5A Secondary output 250mah
- Cutoff method : Delta peak cutoff (Primary & Glow plug port only)
- Maximum charge time: 65 minute safety cutoff
According to the first line, it should do them.
Paul
Paul
