Twin motors set up.
Twin motors set up.
A friend of mine has a twin engines plane in which he has installed two Power 60 motors.
Each has its own ESC and battery. What is the best way to control both from his throttle?
Does he plug one ESC into the throttle, the other into a spare channel and mix them together? Or can he somehow splice them together?
Ray
Ray
RE: Twin motors set up.
a Y cable should work. Plug both ESC into the Y and plug that into the throttle channel. Assuming the two motors run reasonably even, and they should, you want them getting the same throttle signals.
If the radio has the mixing ability, you could put them on different channels and mix them using the radio's mixes. This might give you the option to have them run at different speeds, however this is fraught with danger. But, depending on the radio, this could work.
PA
Castle Creations has a good guide for wiring up twins, check out page 2 of the March 2006 issue of the Scribe Newsletter:
[link=http://www.castlecreations.com/media/castle_scribe_archives/Castle%20Scribe%20CE-03-Mar2006.pdf]March 2006 Castle Scribe Newsletter[/link]
The jpeg below sums up their recommendations:
Thanks for the help guys, much appreciated!
Will try the y lead first, seems the simplest solution.
GA
Cyclops is right, I have a couple twins and a 4 motor, if your ESC has a BEC built in you need to unhook the power wire from one of them.
Using the Y harness to connect the 2 ESC is the easiest way and works fine, you may need to use a flight pack as well for your servo's depending on how many and how big they are, you can just Y harness your flight pack through one of your servo connections, also I would suggest running your batts together so both motors get their power from both at the same time, this will prevent one losing power or cutting out alone and leaving the other motor running
personaly I would rather have both motors cut out together if it's going to happen, then you can rearm them together if you have time
and not have to flight a sudden yawl or even a death spiral due to sudden loss of one motor
PA
ORIGINAL: AJ1202
Cyclops is right, I have a couple twins and a 4 motor, if your ESC has a BEC built in you need to unhook the power wire from one of them...
Thanks AJ,
I think we will have to disconnect the power from one ESC.
Which wire do I cut? I assume the red one coming from the ESC but don't want to make a mistake
GA
It would be the red one BUT DON'T cut it, if you lay the plug down with the side up that you can see the pins, very carefully lift the tiny plastic tab in the open part and then you can pull the wire out of the plug. then just fold it back and tape it to the wire. This way you don't destroy your ESC wire and plug
