DX6i charge indicator?
Is there an indicator light or something that shows the transmitter is actually charging when Iplug it in? How do you know when it's fully charged?
RE: DX6i charge indicator?
If you are using the factory charger, look on it. There should be two LED's on it. One lights up when the rx pack is connected to it, the other lights up when you plug in the tx.
You have the special Horizon/Spektrum Glacier Girl charger, or a newer/older one than mine. Hey, it's good to be liked! With no indicator lights, I use the little volt meter gauge that's on the main menu page with the profile of an airplane/heli on it. It responds to the batt. charge. I hope.http://www.rcuniverse.com/forum/js/f...n/rolleyes.gif
| All times are GMT -8. The time now is 12:38 AM. |
