Sorry for this question
Well we all have to start somewhere !! [:o]
I have just bought a Futaba 6EXA tx and a Hitec Electron 6 rx, i need to swap out my old radio gear, but have no manuals or anything to tell me what goes where. Could someone please help me with where to plug in the servos and esc on the reciever. I have a 3 channel plane at the moment, with throttle, rudder and elevator. I don't want to damage the reciever by plugging in the esc in the wrong place (if indeed this would damage it), so any help would really be appreciated. Thanks, Mark |
RE: Sorry for this question
Ah it's ok, found the help i needed, and all working fine, cheers :D
Hey Mark, you don't have to worry about plugging the servos in the incorrect spot on the receiver. The worst that would happen, is that when you test out your radio you would get an incorrect response. You would do this before trying to fly your plane. As far as ware to plug in the servos, most receiver's just below the port should indicate its function. If it does'nt, you will have to plug them in by trial and error. I'm assuming that you already have your servos in place. If not put them ware you want them and give it a go. Good luck
Henk |
Cheers Henk, i'm getting there slowly with all this, and sometimes dumb questions have to be asked (although no such thing as a dumb question when you don't know i suppose)
The cheap 27mhz am gear that came with the plane decided to cut the throttle 3 metres up from take-off and slam it nose first into the ground, breaking the nose section right off, hence the oh well, get some better radio gear then thought. Hopefully the next time will be more successful, aint giving up though, love it !!! :) |
The only sure way to know which channel does what is to experiment. Luckily you won't hurt anything by plugging it into the wrong channel. Just be sure to stand clear of the prop before turning anything on.
Different radio brands do things differently, and I may be totally off base here, but the same radio brand (e.g. Hitec) does two different things depending on which NATION you're in... Talk about confusing! In the USA, Futaba transmitters have throttle on Channel 3, ailerons on 1, elevator on 2, rudder on 4. Shoot me if I got that messed up, but I am certain of throttle on 3. Rudder-only planes generally have the rudder plugged into the aileron channel, so it's more correctly termed "primary steering," IMHO. |
Ah, well it is all working correctly, but i have the rudder plugged into the rudder channel, are you saying it would be better to plug into the aileron for learning ?
You were correct with the channel assignments, so well done for that :) |
Actually, it's whatever you feel comfortable with. Some people are "purists," in that it's the rudder, therefore it should be plugged into the rudder channel, period, end of story. There are some advantages, like being able to CORRECTLY control the plane with ailerons and rudder when you move to a full-house, 4-channel airplane. Most fliers don't use the rudder on a regular basis, but you can make maneuvers look pretty if you learn to use it.
The other school of thought is based on the fact that most people don't use rudder anyway, so they should learn to "steer" the plane with the aileron control. That way, you don't have to learn a new stick when you switch to a 4-channel plane, or a plane that only has ailerons. |
Ok, i think the best way would be to try both and see what i am comfortable with.
Thanks very much for your replies Matt, i'm learning a hell of a lot from these forums. |
Matt, I too learned a couple of this from you, thanks Joe
| All times are GMT -8. The time now is 08:54 PM. |
