RCU Forums
-   Electric Training (https://www.rcuniverse.com/forum/electric-training-102/)
-   -   Which prop for EStarter? (https://www.rcuniverse.com/forum/electric-training-102/2026047-prop-estarter.html)
jfpalumbo123 07-26-2004 07:13 PM
Just got the EStarter and had first flight last week. I'm using 9.6 720 NiMHs, which according to GWS requires a 9x7 prop. All I had was 10x8s and took it out anyway. Seemed to fly fine. Would the 9x7s would make much difference? I'm not exactly doing 3d here ;) but I do want the correct set up.
Thanks.
stirlingnut 07-26-2004 08:48 PM
RE: Which prop for EStarter?
I run lipolys in my estarter with a 10X80(7.2 volt)But with the higher volts you are running,the 9X70 will be easier on your motor,and probably fly faster and may fly longer due to lower amp draw.
Time Pilot 07-27-2004 01:51 AM
Which motor did you get with the Estarter? The 350 or the 400?
jfpalumbo123 07-30-2004 06:53 PM
actually - I thought it was a 300
thanks for the replies all
bamater 07-31-2004 01:04 AM
I just "graduated" from my estarter a little while back and am moving on to bigger and better things. Here's what I found on my setup. I had a 350C with C gearing. I personally liked the 10x6 prop (w 6-8nimh or a 2 cell lipo) even though it was a little slower on top speed it had alot more torque, which came in handy on those hairy "learning" mistakes. The 10x8 does work fine but was a little faster had more "in-flight" thrust but alot less torque, to me anways. I didn't really like the 9x7 much at all seemed to make the plane too fast for someone learning, but after flying for a while I became ok with it, however I'd still say it was my least favorite prop.....
Something really fun :D(but it will burn your motor up[&o]) is an 11x4.. with a 3 cell pack. I had an esc that could handle it, so near the end of my time with my estart (before I was going to purchase something else) I stripped the landing gear off (landed with belly flops in high grass), lightened it everyway imaginable, slapped the 3 cell in and had a blast, I also "clipped" the wings so it was alot less stable. I could almost hover it [:-] and could do consecutive loops.. after adding "D" gearing and a 12x6 prop I could hover for short times before it would fall out.. But again Do NONE of this until after you've mastered flying it, are ready to move on, and don't mind burning up a motor and hacking your plane up.
Cheers and happy flying,
Bamater
