FROM PUSHER TO PULLER...
I'M DONE CRASHING MY "WINGS " GOING TO CONVENTIONAL PULL AIRCRAFT. WILL I HAVE TO REWIRE MY MEGA MOTORS TO TURN IN OTHER DIRECTION OR JUST FLOP THE PROP??? WHAT IS THE PROPER DIRECTION OF TURN ON A PULLER? I'D ALSO LIKE TO FIND A ONE STOP LINK FOR LEARNING ALOT MORE ON UNDERSTANING THE WHOLE VOLTS,AMPS DRAW,MAH.2C,3C......THING!!! ALLL THE BEST!!! DAVE
RE: FROM PUSHER TO PULLER...
Turn the prop around and wire the motor so the prop turns clockwise when viewed from the rear.
I think you have to switch any two wires on a brushless motor to make it turn in the other direction. |
| All times are GMT -8. The time now is 06:04 PM. |
