EFLITE TRIBUTE FLIGHT PROBLEMS!
I just finished the first flight of my tribute and i had some unexpected results. The controls felt good but it flew nose high at all speeds. CG is dead on acording to the instuctions. Anybody have any ideas to share i could sure use them! thanks.
RE: EFLITE TRIBUTE FLIGHT PROBLEMS!
With the flat plate airfoil, it will tend to fly a little nose high. The lift is completely dependent on angle of attack.
How nose high is it really flying? |
matt
thank you for your reply. Its nose high at about 6degrees or so. I also wasn't flying that fast either. It kind of looked like I had flaps down. Weather permitting I will try to fly Wednesday. thanks again Bob Bloom |
Inverted flight will tell you if the CG is off. If you need a bunch of down elevator, you're nose heavy. I suspect you may be a little nose heavy after mulling it over in the back of my head for a day...
Move your battery more forward. I balance mind by putting a finger on either side of the fus on the front spar, and have it a little more nose heavy and it flys great.:D
| All times are GMT -8. The time now is 05:17 AM. |
