RCU Forums
-   Electric Training (https://www.rcuniverse.com/forum/electric-training-102/)
-   -   Speed Controller size (https://www.rcuniverse.com/forum/electric-training-102/2809429-speed-controller-size.html)
MX240 03-26-2005 09:43 PM
If I have a electric motor that is using 12 AMPS max, what is the harm of useing a ESC that is rated 30 AMPS as long as I keep things under 12 AMPS. Is it because "spikes" of current??
The reason is because this is the ESC that I have on hand.
BadSplice 03-26-2005 10:19 PM
RE: Speed Controller size
The rating on the ESC is a limit, usually it will mean your esc can handle a constant current up to 30 amps (and probably bursts up to 45amps) if your motor is only drawing 12A, its way below that limit, and I dont see how that could possibly hurt anything.
Geoff_Gino 07-21-2005 09:20 AM
Hi MX240
BadSplice is right. No harm in using an over rated ESC, just means that it won't get hot when running the motor flat out. The motor will tho'
Geoff
