HiTec Electron 6 rerceiver
I am putting together a Sig Kadet EP-42, I have chosen a HiTec Electron 6 FM DC RX. The plane uses independent aileron servo's and I'd like to setup and use flapperons. The receiver has 5 channel slots and a battery/charger slot.
In programing the Futaba 7C Transmitter to handle flapperons, the instructions calls for the second servo to be plugged into channel 6 on the Futaba receiver. The HiTec Electron only having 5, can flapperons be used? If so, how would they be set-up, both on the RX and Transmitter? thanks |
RE: HiTec Electron 6 rerceiver
I was just reading about this last night since I'm setting up a Mini Funtana, I believe it said you can change it to channel 5. If your manual is the same as mine, look at page 43, and I believe this is where you change it from 6 to 5. Good luck. Ohh I didn't really read your post correctly...the battery slot is channel 6, but you can change your left aileron to channel 5 if you wish.
thank you very much!!!
| All times are GMT -8. The time now is 09:24 AM. |
