Battery Question
I am just getting into flying and I want to start with electric. I plan on purchasing a triton charger because it will charge most batteries. Is this a good idea?
Also will Great Planes Lithium-Polymer 1500mAh 7.4V 2-Cell Pack work in a Slow Stick? I would like to go with Lith poly where possible because of supiour power. It says it requires 2/3 AA cells 270-400mah or AA cells 600mah 7.2V. This battery stuff is complicated. Also do the speed controlers feed off 4.8V to the receiver and give the full voltage to motor? Thanks for all the info! Dan |
RE: Battery Question
I don`t know the Triton, but have heard that people are pleased with it! I use Schulse myself, and I`m really pleased with it, use it daily and have gained full control of all my batteries, LiPo, LiIon, NiCd and NiMh`s :) And I have a lot of batteries... Don`t dare to count :eek:
Have no idea of what works in a SlowStick, but you sure will get answers to that from others. The most of the speed-controllers (ESC) will feed your receiver and your servos (max 3 or 4 servoes...) as long as we talk low voltage motorbatteries and the ESC is not of the Opto-type (for brushless motors) Yes all the battery stuff can be a little complicated in the beginning, but after all there are some simple rules combined with experience which makes it all less complicated as you gain experience. There is in fact one main factor which is the most important; Current/amperes. Don`t load your motor too hard (amperes) and don`t load your batteries behind their specs (amperes). Beware: Flying is so fun you can be an addict before you know!!! |
Electric flyers have an advantage over glow and gas flyers. We don't have to
buy flammable liquids that have to be stored and handled. And there is no issue around exhaust residue. The planes are quiet and generally neighbor friendly. However we do have to know more and invest more in battery chargers and batteries. For the other guys, the charger that comes with the radio system may be all they will ever need. For us, these are our fuel tanks and filling stations. Let's look at batteries and chargers. I am not going to go into battery chemistry. Let's just say that you need to use the right charger for the right battery. Don't mix and match or you could create a dangerous situation. Used properly they are all safe to use. If you want to know more about NIMH, NICD and Lithium batteries, these links contain useful information. Battery Basics: http://www.modelaircraft.org/mag/FTGU/Part8/index.html Notes on Lithium Batteries http://www.*********.org/lithium_bat...eakthrough.htm safety warning on Lithium Batteries http://www.modelaircraft.org/safetycom.asp Transmitter and Receiver Batteries Just a few words on transmitter and receiver packs. These are typically made from NICD or NIMH cells that are designed for lighter loads than motor batteries. As such, they need also to be charged at slower rates. The general rule is 1/10 C charge rate where C is the rated capacity of the battery. So, on a 600 mah transmitter or receiver pack would be charged at 60 mah. At this rate you would charge an empty pack for 10 hours to bring it fully up to charge. This is handled nicely by the charger that comes with the radio system. This is an example of such a charger. The key is to read the instructions that came with your radio and follow them. http://www2.towerhobbies.com/cgi-bin...&I=LXNK66&P=ML Quick charging these packs is not recommended as a standard practice. However some people will quick charge them if they run down at the field. Just be aware that this can lead to a shorter life and can cause pack failure. If you do quick charge, try to keep it below the 1/2 C level and don't do it too often. They just don't like it. If you quick charge them, they will likely get hot. Don't quick charge them in the plane or the radio as the heat build up could damage some of the surrounding electronics or might deform plastic or epoxy based components near them. Fast charging at 1C will generate a lot of heat and can lead to early pack failure which could happen during a flight. There are after market chargers that are focused on transmitter and receiver packs. Here is an example from AccuCycle http://www2.towerhobbies.com/cgi-bin...&I=LXL357&P=ML Charge 'em slow and treat them right and they should last for years. If you tend to fly for long periods, pick up an extra transmitter and/or receiver pack and charge them slowly, at home. Then, you can just swap packs at the field. That is what I do. Most radio makers offer extra packs and there are a number of third parties that make them. Here are a couple of examples. http://www2.towerhobbies.com/cgi-bin...ry&FVPROFIL=++ http://www.amondotech.com/index.asp?...S&Category=228 Nuff on transmitter and receiver packs Motor Packs The motor on the typical parkflyer needs to pull power at a much higher rate than a receiver pack can provide. So the batteries that power the motors are typically of a different design/grade so that they can supply electricity at these rates. As a result when we charge them we can charge them much faster too. The general rule here is that NICD motor packs can be charged in the 1.5 - 3C range with 2C typical. NIMH packs are best charged at 1- 2C with 1.5C typical. Higher performance packs can take the higher rates. See what the maker recommends. This way you can get in your flight, then put the battery on a charger and be ready to fly that pack again in 15 minutes to an hour. Have 3-4 packs and 2 field chargers and you may never have to stay on the ground for more than a few minutes. That's the way I do it. Lithium motor batteries are becoming popular. However their chemistry is very different from NICD and NIMH cells. As a result they need a different type of charging process. If you are using Lithium packs, you MUST use a charger that is specifically designed to charge lithium or you could end up with an explosion and/or a fire. This is not joke. Don't ever put a lithium pack on a charger that is not designed for lithium cells. Follow the charge rate recommendation of the battery maker carefully! Video of a lithium battery being overcharged. http://rc.andersh.com/video/lithiumbattery.wmv S and P terms When we talk about battery packs, a designation of XSYP is sometimes used. This indicates how may cells are in serial and how many groups of these cells are connected in parallel. While the terms are most common in the Lithium world, they can just as easily be applied to NIMH or NICD packs. So a 3S2P pack is made up of 6 cells. There are two groups of 3 cells. The three cells are connected in series. This is the 3S designation. When connected in series their voltages add. So 3.7V Lithium cells in a 3S configuration would have a voltage of 11.1V and be designated as a 3S1P pack. If these cells were rated at 2000 mah each then this would be a 3S1P 11.1V 2000 mah pack. Now if we took two of these 3S1P packs and connected them in parallel, the capacity adds, not the voltage. So this would now be a 3S2P pack rated at 11.1V and having a capacity of 4000 mah. Like connecting two gas tanks together. The motor in you truck would not be stronger but you could drive further because you are carrying more fuel. You could do the same with NICD or NIMH packs. An 8 Cell NIMH pack of 1.2V cells is rated at 9.6V and could be designated as a 8S1P pack. You are not likely to see this, but it would still be accurate to designate it this way. It is like Sr. and Jr. on my name. My Dad was not a Sr. until I became a Jr. There were not 8S1P designations for NICD or NIMH until the lithium's came along. You are still not likely to see it for the NIXX packs. Battery Chargers There are timed chargers and peak chargers. Timed chargers, often bundled with RTF airplanes, work well if you always run your pack all the way down. Otherwise they can have a tendency to over charge the packs. If you have one, run your battery down and go ahead and use it, but I don't recommend you go out and buy one. Peak chargers, are the way to go. They read the pack and know when it is fully charged. An AC powered charger is convenient to use at home, but won't help you recharge at the field. A DC peak charger that can run off your car battery or a flight box battery will allow you to charge at the field. There are AC/DC chargers as well. All of mine are DC peak chargers except for my radio chargers. I have a car booster pack that runs my DC equipment in my shop. And, by the way, I have used it to jump start cars. Works great! This is similar to the one I have. http://www.sears.com/sr/javasr/produ...id=02871472000 While many peak chargers are focused on charging motor packs, most also have low charge rate settings that can be used to charge receiver packs so you can use them at home, or in the field to refresh you radio or receiver pack at the field during a break. Here are a few examples of peak chargers for your consideration. I have the first three shown here. HobbyZone Peak Charger - $19 Simple and inexpensive - I have 2 of these from my Aerobirds I added different types of connectors so I can use them for all kinds of battery packs. They work just fine. 4-7 cells NIMH and NICD http://www.horizonhobby.com/Shop/ByC...ProdID=HBZ1026 Hitec CG-340 - $39 I have had this one for 18 months. Does not come with charge leads - You need to make or buy leads Easy to use for NIMH and NICD - up to 16 cells - More flexible than the HobbyZone charger and it handles larger packs. I feel it gives a better peak charge. It can also charge at higher currents, especially for NICD batteries. http://www.horizonhobby.com/Shop/ByC...rodID=HRC43340 Triton Charger - $130 - This one showed up under the Christmas Tree - :-) Better than the CG-340. It handles up to 24 cells NICD/NIMH cells or 4 cell Lithium cell packs as well as Lead/acid field box batteries. It will also cycle battery packs which my others will not do. So far I am very happy with it. http://www2.towerhobbies.com/cgi-bin...&I=LXCJG7&P=ML Reviews http://www.rcbatteryclinic.com/triton.htm http://forums.radiocontrolzone.com/p...d.php?t=135705 http://www.rcuniverse.com/product_gu...product_id=19\ I don't have these but have heard good things about them. GWS MC 2002 Peak Charger - $49 Seems to be a good value for a first charger for NIMH and NICD packs of 4-12 cells. It has charge meter, but not the digital display or memories of the Triton or others. Includes a variety of connectors. It can not slow charge receiver/transmitter packs due to 90 minute charge time cutoff. http://www2.towerhobbies.com/cgi-bin...?&I=LXHHV3&P=7 http://www.horizonhobby.com/Shop/ByC...ProdID=GWS3000 http://www.gws.com.tw/english/produc...it/charger.htm AC/DC MRC Super Brain 969 - $95 http://www2.towerhobbies.com/cgi-bin...?&I=LXEVC7&P=7 Peak charger, Dual independent outputs to charge 2 packs of 1-8 cells, at once. Discharge function allows you to get the most out of your batteries LCD screen shows: battery voltage, charge rate, peak threshold, capacity, number of cells in pack, & elapsed time For 1-8 cells any capacity NiCd, NiMH batteries only Selectable charge rate with 0.1 amp increments Selectable delta peak voltage thresholds in 5mV increments Great Planes PolyCharge4 DC Only 4 Output LiPo Charger - $100 http://www2.towerhobbies.com/cgi-bin...?&I=LXKAU0&P=7 If you are seriously into LiPoly ( not Li-ION) This may be the charger of your dreams. Charges 4 Lipoly packs at one time. Each charge port is limited to 30 watts, so it can charge 1S or 2S packs at up to a 3 amp rate. 3S packs can be charged at up to about 2.5 amps and 4S packs can be charged at about 2 amp rate. Therefore, this charger seems a very good choice for 1S or 2S packs up to 3000 mah capacity, 3S packs up to about 2500 mah and 4S packs of up to about 2000 mah. You can charge packs of higher capacity but it will take more than 1 hour to charge based on the typical 1C charge rate for LiPoly packs. If you have packs with a 2, 3 or 4P designation, this charger might also be good for you. 3S4P packs up to about 10,000 mah would work well if each 3S component can be charged separately. 4S4P packs up to about 8000 mah would also work, if you can charge them as four 4S1P packs of 2000 mah each. Discussion thread on this charger http://www.rcgroups.com/forums/showt...4&page=3&pp=15 A review of a group of Lithium battery chargers http://www.rcgroups.com/links/index.php?id=4676 Cheapest way I have seen to run your 12 V charger indoors is to get one of these Field box batteries http://www2.towerhobbies.com/cgi-bin...&I=LXL370&P=ML $18 And one of these chargers - $10 http://www2.towerhobbies.com/cgi-bin...?&I=LXL353&P=V There are many other good chargers out there. The first three are the ones I use every day. I have accumulated these over time as my fleet and my budget has allowed. Each has given me good service within its capabilities. Sometimes I have 3 chargers running at the field at one time charging motor batteries for my parkflyers or receiver batteries for my sailplanes. I hate being grounded. So they are put to good use. I invite others to provide insights on the subject or to recommend chargers that have served you well. |
Thought I would add one. The Hobbico Quick Field DC Charger MKII 12 Volt:
http://www2.towerhobbies.com/cgi-bin...?&I=LXCTZ5&P=0 I'm new to electric flight, so I don't have anything to compare it to. But it works well for me. Charges NiCD, NiMH, and Lipo. Has two sepparate charging "stations" so you can charge two batteries at the same time. Has variable charge rates, and jacks for monitoring battery with a volt meter. Since it's 12V, when I'm using it at home, I plug into my DuraTrax power supply: http://www2.towerhobbies.com/cgi-bin...?&I=LXUF47&P=7 |
Welcome to the family Tarence.
Here are my notes on eFlight stuff. [link=http://www.alaweb.com/~mtexx/eflight_glossary.html]eFlight Hyper Glossary[/link] |
Thanks for all the great info! The info at this site is great!!
| All times are GMT -8. The time now is 02:58 AM. |
