tips for kits for small fields?
I'm a teacher at a highschool with 10 students in a new "Aviation" club. I'm a newbie myself (have private pilot license and glider license
but not much experience with RC), so this is a real adventure!! They have started with parkflyer electric ARFs - Decathlons, J3 Cubs, an Aerobird Challenger. These have proved to be OK except our school fields are a bit small and have tall trees around the outside ... see my posting, "stuck in a tree" :( ha ha We may soon have another place to fly that's giant! but it takes 20 minutes to get there which would eat into our time. Plus there's a bull in the field! I'm looking for help selecting their next models. I have specified they must take more skill/art to build.... I've suggested 20-40hrs, balsa and monocote. If it takes longer than we have, some kids said they'd be happy to continue building after school's out. They've been interested in several so far (aside from some hot fighters!!) House of Balsa Electric Acro Cub Schoolyard Kit 52.5" Miss Stik Razor Cut Kit 55" Great Planes ElectriFly ElectriCUB Kit 58.75" My questions: Are these suitable? I suspect from what I've been reading from some Backyard Flyer mags a friend gave me that they're a bit big and heavy to fly safely in the school baseball/rugby field. But what do I know, I'm pretty new! What is the quality of these kits? If not suitable, where can I look for other kits better suited for small fields? What wing loading, weight, and power guidelines would be good? I've suggested less than 13 oz/sqft, less than 400 speed electric, and less than 4 lb overall weight as a starting guideline that I'll modify as I learn more. For next year, I might consider indoor electrics. I'll go read the forum on that now -Carrie -Stick forward, houses bigger. Stick back, houses smaller. Then bigger again. |
RE: tips for kits for small fields?
For your space, I'd stick to the park flyer category. Bigger planes need a bit more room. I've listed some links to planes that may fit your needs.
The Great Planes Tutor--I've flown the stick version (BLT) and found it was a good step up from a very basic RC Trainer. The mini Telemaster is also, from what I've heard, a good trainer. I followed a thread for the MiniSport from someone who quite enjoyed it; it may not be the best to learn on, but students can always build them and fly them once they've gained experience. http://www.greathobbies.com/products...od_id=GPMA0002 http://www.greathobbies.com/products...rod_id=HLIA101 http://www.greathobbies.com/products...rod_id=HRRK304 Something else to consider is an intermediate build, like the GWS Estarter which is a great 4 channel trainer. It wouldn't take 40 hours (but then, maybe!), but you can go through the Ultimate Estarter Threads, do some of the modifications, then finish it by filling in the surface of the foam and covering it with low-heat shrink film. If you power the stock setup with a light battery, it should fly okay, although if get the version without the power system and put in a cheap brushless motor it will fly much better. It all depends on what you want and what kind of abuse the kids will put the plane through. If it's going to get abused, I'd be thinking forget nice and make it servicable. It generally takes longer to repair a crashed balsa plane than a foam parkflyer. |
| All times are GMT -8. The time now is 01:22 PM. |
