RCU Forums
-   Electric Training (https://www.rcuniverse.com/forum/electric-training-102/)
-   -   Beginer electric flyer question (https://www.rcuniverse.com/forum/electric-training-102/540126-beginer-electric-flyer-question.html)
woodfieldairpla 02-07-2003 05:45 PM
I have what I've been told is a Great Planes 75 electric motor that is set up with a 8X4 prop. I plan to use a 6 cell NiCad pack to power an old timer that will weigh about 40 oz. Does sound like a reasonable set-up for a beginer? The wing loading is 9.0 oz./sq. ft. Also, I'm looking for an ESC with BEC and about 20amp capacity. Can you suggest a brand and source? Is this something I might find in the classified adds given the run of the mill specs? I'm trying to get started with electrics and have not found a comprehensive guide to motor sizing. What is the significance of the numbers associated with the motors I see advertised?
Tippie 02-07-2003 08:06 PM
You have a lot of questions so I suggest that first you get a little electric orientation at the following web site: www.ezonemag.com On the left column click on "FAQ" and you will get answers to a lot of your questions. Now, you said you think you have a Great Planes 75 motor. I went to the Great Planes web site and the only thing I could find that may relate to that is a motor system with the catalog number of 'GPMG0755' which has a S-600 motor and according to their blurb will handle an airplane up to 50oz. ? The motor voltage is 7.2-8.4. Don't think you will be happy with a 6 cell battery, better to get a 8 cell battery at least 1000-1200mah. The 8x4 prop is the suggested prop for that motor but that depends on the airplane. A 20amp ESC will be insufficent. You need at least a 30amp ESC. Check ESC specs to see what you may want. Great Planes has ESC's. Their ESC's have a safety for arming the motor which prevents the motor from running when you first turn on the receiver. With their ESC you have to move the throttle to full and then back to idle before it is armed. It also has a plug if you want to disable the BEC feature. As far as motor comparisons, there is none. There is no standard for electric motors used in the hobby. The FAQ's will give you info about the numbers used for electric motors. That will be all of the homework for you tonight. Good Luck!! Above all get experienced help with the airplane and assistance in learning to fly. Should be a local hobby shop that can advise you as to a club that will get you started in the hobby.
woodfieldairpla 02-07-2003 08:21 PM
Thanks for your help.
Tippie 02-08-2003 12:51 AM
Just to add to the information. You may want to look around the "Ezone" site and perhaps click on the "Archives/columns" and see if there is anything else that will help. Ezone is dedicated to all electric modeling and have a monthly internet 'magazine'.
