battery question
have decided to try my hand at making my own battery packs. i know that when i solder batteries together that i miltiply voltage, does this also multiply mah.
RE: battery question
When you connect cells in series, you multiply voltage. When you connect cells in parallel, you multiply capacity (mAh).
- Jeff |
| All times are GMT -8. The time now is 12:13 AM. |
