Electric suggestions
Hey guys!
I ave a Hanger9 P-51 Mustang that I'm going to make electric. Wingspan: 65.5 in Wing Area: 745 aq in Fuselage Length: 55.75 in Weight (Appox.): 7-8.5 lbs Recommended Engines: 2-cycle .60-.78 I have two Flight Power 6s 500mah Lipos 750 grams I want to use (Keep in mind I could wire them to make 12s if needed..... could be over kill though). What motor, ESC, prop should I use? What will my flight times be like? Do you think my Lipos are to heavy? Open to suggestions... Thanks Jeremy |
RE: Electric suggestions
Lithium - perhaps try posting this in the glo to electric conversion area.
SELECTING ELECTRIC POWER SYSTEMS
Reference Resources Electric airplanes can be lots of fun and very little work. There are lots of RTF planes that already have their power systems selected and installed. They require no work at all on your part. That is about as easy as it gets. If you like ARFs or kits, many come with motors and props standard. Some will include a gearbox as well, if the designer considers that the best approach. While these may not be the most powerful motors you might put on the plane, you can be reasonably confident that they will fly the plane. The instructions will normally recommend an appropriate sized electronic speed control, ESC, and battery pack to use with that motor and propeller combination on that plane. Just read the friendly manual, RTFM, and you can usually get the plane in the air with little trouble. That is still pretty easy. But what if you want to design a power system yourself. Perhaps you are converting a glow or gas plane over to electric power. How would you go about doing something like this. This is not a trivial task. There are many factors to take into consideration and there are hundreds of motor, ESC and battery pack options out there. How do you choose? Or say you want something better or stronger than the motor that came with your plane? And, of course, some ARFs and kits don't include motors. And finally there is the fun of designing your own planes. Now you need to plan the power systems. If you are going to design your own systems you will need some help and some knowledge. What I have compiled is a list of links that take you to resources to help you. First I recommend you read this article for background information. It will help you understand and use the rest of the resources listed below. Sizing Electric Power Systems - http://www.rccyberflyer.com/forum/showthread.php?t=272 Remember that the system operates as a whole. If you have the right motor with the right battery and put on the wrong prop, things can get pretty ugly pretty fast. I highly recommend you pick up a wattmeter. If you are going to be a designer there are only two ways to know if you got it right. The first is to measure the amps, volts, watts being drawn by your new power system and making sure all components are up to the effort. The other way is to see the plane fly badly, watch your new motor burn up, your new battery pack fail or see the magic smoke come out of your ESC. Personally I would rather you get a wattmeter. This thread discusses their value and uses. Several are discussed. WATTMETERS - Vital to the power system designer http://www.wattflyer.com/forums/showthread.php?t=11863 Brushed vs. Brushless motors Many RTF, ARF and Kits come with brushed motors. These are often identified by a "speed:" designation such as speed 280, speed 370, speed 400, speed 600 and so on. They work fine but are less powerful and less efficient than brushless motors. If you are going to design your own power systems I suggest you go directly to the brushless motors. Prices have come down a lot and quality, even at the low end, is good. So leave the world of brushed motors behind and go brushless. From this point forward I will only be looking at brushless systems. Resources Some manufacturers have done a good job of providing tables and charts that can help you use their components to come up with the right system. Armed with the knowledge from the first article you are now better equipped to use them. The ones I have found most useful are next. Some retailers have also gone to a package approach to take the guesswork out of the effort. They combine a motor, ESC, mounting hardware in to a package. Some include battery pack recommendations and may also provide wiring options as well. MAXX PRODUCTS Maxx Products - How to Choose a Brushless Motor for an Airplane pretty good tip sheet on coming up with a glow to electric power comparison. http://www.maxxprod.com/mpi/tips3.html HiMaxPower System Packaged sets and info chart Motor, speed control and prop all matched up for you http://www.maxxprod.com/mpi/mpi-264.html ELECTRIFLY Guide to Glow to Electric Conversions http://www.electrifly.com/manuals/gp...-elec-conv.pdf Electrifly Electric Motor Configuration Tool It assumes you know where you are going. Read the article above and you will be better prepared to use this too. http://www.electrifly.com/config/ Brushed motor to Brushless Motor Conversion Chart The recommendations will yield a significant power boost. http://www.electrifly.com/powersyste...brushless.html Chart of Sample Planes and Recommended Power Packages http://www.electrifly.com/powersyste...nversions.html Electrifly Brushless Brochure. Lots of useful info that you can print out. It is only for Electrifly components, but it is well done. http://www.electrifly.com/sellsheets...m-brochure.pdf GWS GWS provides excellent information about their brushless motors and how they perform with different batteries, and props. Useful, once you understand the watts/pound rules. http://www.gwsus.com/english/product.../brushless.htm SkySharkRC Prepackaged Electric Conversion kits for .50 and larger glow planes Includes Motor, battery, ESC, mounting and connectors http://www.skysharkrc.com/shop/?shop...27&cart=125763 Hobby-Lobby Packages Glow Planes with appropriate electric conversions. This can be an excellent source for the whole thing, or you can use their conversion as a reference for your own conversion planes. http://www.hobby-lobby.com/glowtoelec.htm In addition, Hobby-Lobby provides excellent information about the motors they sell often providing motor, prop, battery stats to guide you in picking your own components. Their on phone sales people are very good and have excellent resources to back them for designing electric power systems. http://www.hobby-lobby.com/brushless-motors.htm Other Resources A series of posts on electric power system basics http://www.wattflyer.com/forums/showthread.php?t=1933 http://www.rcgroups.com/forums/showthread.php?t=417868 MotoCalc will tell you everything you need to know: Amps, Volts, Watts, RPM, Thrust, Rate of Climb, and much more! It is a popular tool for predicting the proper motor, prop, battery pack for electric planes. Read the fist article first and this will make a lot more sense. http://www.motocalc.com/ Amps vs. Volts vs. C http://www.ampaviators.com/index.php...d=37&Itemid=27 Low Voltage Cutoff http://www.wattflyer.com/forums/showthread.php?t=3445 |
lithiumstatic: Check the Glow to Electric Conversion forum. Greg Covey has been reviewing this plane for conversion and there are 9 or 10 pages of posts with lots of information. Don't be surprised when you find out that you are going to need a LOT more battery than what you have. Big electrics = big motor, big ESC, big batteries, BIG bucks (at least for the average spender like me).
I think he meant the batteries are 6S5000, not 500...?
If the setup is 12S it could fly on only 30A load, but there are two problems: you have to find a motor which take 12S. And you have to find an ESC which take 12S. They are there, but in the upper price-class. If ran as 6S there is an other problem: it have to handle 60A at least. Just an example: AXI 4130/16 on 18,5x12 propell could get that bird airborne with 6S. Any good ESC in the 70-90A range. And an UBEC. Flight time: appr. 7-10 minutes. |
I need at least 15 minutes of flight.... 20 would be even better. I sold the 6s 5000mah Lipos.
This is what I'm thinking...... Castele Creations Phoenix 85HV Hacker A50-12L or A60-16L Not sure what battery.... Suggestions? |
Project was abandoned due to death of my father in 2017. Thanks for the replies.
| All times are GMT -8. The time now is 10:06 PM. |
