soldering
well i just got my esc/rx and it want's me to solder on capacitators, it says that they cut down possible interferance, well i have a soldering gun but my soder is junk so it just isn't working out, i got the esc wires on and they are solid but the capacitators are causing trouble, I'm just wondering if they are really nessecary
Thanks, Austin |
RE: soldering
yeah, you should realyl get them on there. They do make a big difference. Also on most brushed motors (ok all that I have seen) make sure to solder the negative lead off of the cap to the side of the motor, or solder 3 104 caps, one between the case and the positive pole, then one between the case and the negative pole, and then one between the 2 poles.
RE: soldering
Hi acarter,
You would probably do better with a soldering iron than a soldering gun. Something like this from Radio Shack will do nicely. http://www.radioshack.com/product/in...entPage=search Also, pick up some new solder while you're at it. http://www.radioshack.com/product/in...entPage=search |
RE: soldering
thanks guys, i think i'll go to radio shack tomarrow and maybe get a flight in
| All times are GMT -8. The time now is 09:14 AM. |
