Help with E-Flite 160 w/TP5000-10s setup
I've only been involved with electrics for a year now and was hoping for
some sound advice on my setup for the conversion of a Nitroplanes Falcon 120 jet. This plane is designed to handle a 120-160 2 cycle engine in a pusher configuration. After modifying and beefing up various structures in the plane my final ready to fly weight came out to 15.6 lbs. I've converted the jet to use the E-Flite 160 motor along with the TP5000-10s lipo and Castle Creation HV-110 setup. Unfortunately, the largest props I can use would be a 18" prop cut down to 17" due to the twin boom design and landing gear. I have tried several props thus far, all regular APC's. 13.4 x 13.5 3-blade 15.5 x 12 2-blade 16 x 13 2-blade I plan to test a 16 x 12 and a cut down 18x8 to 17X8 APC electric. The stats on the E-FLITE 160 say this motor can handle 60A continuous and 78A max. burst, inputting up to 2700 watts. The best performance so far comes from the 16X13, pushing my weight scale to 12 lbs. The numbers I'm getting on my watt meter never exceed 1400 watts and average around 45 amps. After testing the 16X13 prop at various speed it seems like the most I'll get is about 6 minutes flight time with careful throttle use. Also the pack and motor were warmer than expected but the ESC was still cool to the touch. My question centers around how to get the best performace out of this setup with a limited prop selection? I would like to get an optimum setup inputting around 130-150 watts per pound (=2028 watts+) without taxing my system. Should I try and stick with electric props? Trying not to buy a bunch more props to get it right! Thanks in advance for you help! Keith |
RE: Help with E-Flite 160 w/TP5000-10s setup
Moderator,
Can this post be moved over to the "Brushed/Brushless motors, speed controls, gear drives" thread? Thanks, Keith |
You're pretty much stuck with buying a motor with a higher kV, Keith. Check out the Dualsky motors in that weight range (don't go much heavier).
-Adam |
Thanks for the reply Adam,
After giving it some thought, I kind of figured I would either have to go to a smaller motor (E-flite 110) or increase the voltage. At this juncture increasing the voltage in not something I want to invest in just yet. With all the varied props I have it would be much cheaper to buy a smaller motor with more kV. Who makes the Dualsky motors? Thanks Again, Keith |
| All times are GMT -8. The time now is 06:00 AM. |
