Gws Beaver
Not really a beginner, but it's been 20 years since I have flown. I bought a GWS Beaver to get back in. I like the looks of the kit, but feel that the tail section for the plane is really too thin. I have been looking in other parts of the forum, but no one has adressed this problem(if it is a problem). What I would like to know is if you think these pieces could be made of balsa with any problems? I plan to build the plane according to planes except for the landing gear, which I am using a set of 2 in Du-Bro lite weight wheels. Any suggestions would be welcomed.
Thank you. |
Gws Beaver
I don't have a GWS Beaver, and I have only seen 1 fly. The one I saw fly was a stock plane with no modifications.
The only thing I have heard about is to beef up the wing struts a little. GWS Planes have a solid reputation if kept within the boundaries of what they were designed to do. I would be very hesitant about changing the tail surfaces unless someone answers you saying it must be done. Keep your added weight down to a minimum on these small parkflyer electrics. Weight is your enemy, much more so on a parkflyer than a glowplane. Keep it light and do your first flight with little to no wind and you should have a blast. Welcome back to the hobby! |
Gws Beaver
Thanks latch66,
I plan to build the plane according to the instructions except for the wheels. Just wandering if anyone else had the same thoughts. Thanks again, cyclone |
Beaver
Just build it as per the plans, but yes, the wheels have to go.
Flys great, tail is O.K. Jetts |
Gws Beaver
Thanks for the reply Jetts. I am going to build as pr planes. Just thought tail was a little thin. Guess I am still use to building in balsa.
Gws Beaver
The tail IS a little thin. Mine, built box-stock, no hangar rash, violent maneuvering, or crashes was drooping after the first flight.
First, I tried to stiffen the tail with some fiber tape. That didn't work. I ended up cutting a slot out of each side, and installing a bamboo skewer spar. After that, the tail was very solid and worked well, until I crashed it and broke the skewer where it entered the fuselage. It's now since been repaired, and is up for auction on Ebay if anyone is interested ;) |
Gws Beaver
Thanks for the reply mkirsh. I am just starting to build the plane. Will try your suggestion. I will try to run the skewer spar across the tail before I install it.
| All times are GMT -8. The time now is 06:45 AM. |
