RCU Forums
-   Electric Training (https://www.rcuniverse.com/forum/electric-training-102/)
-   -   esc (https://www.rcuniverse.com/forum/electric-training-102/7230619-esc.html)
gg1945 03-15-2008 08:13 PM
esc
I just assemply a e325 titan. The servo work but pluged the motor in and nothing happen. How do i program the esc. there is no beeping. I have a spektrum dx7 radio, Helio & radio are new as am i to radio controled helio.
email address [email protected]
dignlivn 03-15-2008 09:54 PM
RE: esc
What type of ESC ? need more info to help.
Bob
gg1945 03-16-2008 02:47 PM
RE: esc
It a brushless ACE RC BLC-40 40A No. 8041
jdetray 03-16-2008 05:55 PM
RE: esc
Do you have the instructions? If not, I found them online [link=http://members.home.nl/e.gubbels/Manual/TTR8041_43_BrushlessESC.pdf]here[/link].
- Jeff
gg1945 03-16-2008 09:03 PM
RE: esc
Thanks ! I didn't have any instructions. Going to try tomorrow.
This is all new to me.
hellblastervolly 03-20-2008 02:45 AM
RE: esc
Hi gg1945.
If you still having problem, try moving the trottle stick all the way to full position in your spektrum dx7 radio before connecting your battery. Some ESC arm on the up position and if you don't do this it whon't finish setting up.
Fernando
gg1945 03-20-2008 07:18 PM
RE: esc
It beeped at full throttle but would not beep at idle. Now it would beep at all
Flypaper 2 03-21-2008 08:15 PM
RE: esc
Go into the programming and go to travel adjust. Where it says (throttle low)keep going to 150% till you hear the motor beep then stop. Also put the throttle trim by the stick all the way down.
hellblastervolly 03-21-2008 11:47 PM
RE: esc
Many of the company recomend that you have your travel set 100% and the trims on 0% but what flypaper said it may work. If you still having problem find a friend or your LHS that have a funtional ESC and check if it work with your motor by been able to program it and beep every time it's supposed to. If it dose you may have a defective ESC, take it to your LHS and have them check it there also. It can also be the motor, I had a motor that gave me problem and the first sign was the volume of the beep start getting lower and lower until you could not hear it unless you stick your hear close to it. So maybe your ESC it's working but you can't hear the beep because the motor and thats why you said that now would not beep at all.
Fernando
