is Futaba R114F 4 ch really only three ?, need help
I have a 114f rec. which is 4 ch but there are only 4 spaces to put a plug and 1 is batt, is there a cable to use the 4th slot as both batt. input and servo ??
RE: is Futaba R114F 4 ch really only three ?, need help
Is this your receiver?
http://www3.towerhobbies.com/cgi-bin...&I=LXASY4&P=ML It is always best to provide a link so there is no confusion. If you are going to use it with an ESC, then the power is provided to the receiver via the ESC and there is no separate battery needed. In a glow or glider you would have a receiver pack. If you wanted to use all 4 channels then you would us a Y cable to attach the receiver battery. |
