Best paint for polystyrene
Sure this must have been discussed before (sorry) but I need to repaint the wings of a Wing Dragon that has just been repaired after going through the mincer a couple of times, and was wondering what paint to use.
Obviously need something that's thin, light, and doesn't eat wings for breakfast. Thanks! |
RE: Best paint for polystyrene
Are you wanting an exact color match, or will any color do?
Krylon's H2O paint is probably the safest since it's water based. However, it's likely most any spray paint will work if you put in on in very thin coats and have the spray can far enough back so most of the solvent has evaporated before it touches the foam. Be sure to try it on a piece of scrap foam first before you spray it on the real thing. |
| All times are GMT -8. The time now is 05:03 AM. |
