First Electro Acrobatics
I bought a PZ Trojan after messing around on their cub. The trojan has given me a chance to start training in acrobatics. I can loop and do hard banking turns. Steep dives and even fly inverted for two seconds before getting scared. MY question is with barrel rolls. When i roll the plane it has the tendancy to roll sloppy. Its not a tight roll at all and the plane has a tendancy to dive during part of it. I have seen stock Trojans in videos pull off nice tight straight rolls. How is this done?
RE: First Electro Acrobatics
Hi MrGerbik,
The roll of the plane is a function of several factors. The ones that you can most easily control are the degree of deflection of the ailerons and the speed of the plane. If your transmitter allows you to choose low rate and high rate for the controls, you will find the plane rolling much better on the high rates than on the low rates. Basically, the slower the plane flys, the slower and slopier the roll will be. If you fly your Trojan at 50% throttle and have it set to low rates, you will get a very sloppy roll. If you fly it at full throttle and have it set to high rates, you should get a nice crisp roll. When a plane banks, the wings provide less lift than when it is flying level, so the plane starts to loose altitude. For this reason a little up elevator is needed when a plane banks into a turn to keep it flying level. A roll is a bank taken to the extreme, therefore a plane is naturally going to lose altitude during a roll. If you angle the plane slightly up when you begin the roll, the impact of the lost lift is minimized. |
I always fly high rates. Not once have tried it at low. Ill try with more speed however and a little up elevator. Problem is getting over the fear at doing the trick while at highspeed
MrGerbik -
What you are trying to perform is an axial roll. A barrel roll is something else and is actually more like the sloppy roll you are already performing. Here's a page that explains better than I can: http://www.jetplanes.co.uk/modelairc...obatics-2.html - Jeff |
Thanks alot. That link actually cleared up alot. I'll try it out next time im out there
| All times are GMT -8. The time now is 05:17 AM. |
