RCU Forums
-   Electric Training (https://www.rcuniverse.com/forum/electric-training-102/)
-   -   Is this correct about charging Lipo's (https://www.rcuniverse.com/forum/electric-training-102/7824700-correct-about-charging-lipos.html)
UH60 Crewdog 08-08-2008 04:08 PM
I copied and pasted this from another forum...If I have a 4S 4200Mah does this mean I can charge (safley) at 4.2 amps or 85% being 3.5 Amps.
The standard recommended charge rate is 1C, which is calculated by taking the mah of the pack and dividing by 1000 to get a amp number for charging.
3300mah / 1000 = 3.3amps - that would be the standard recommendation.
I like to play it safe, and take extra special care of the packs, so I run 85% of the standard recommended charge rate
3.3amps x 0.85 = 2.8amps
jdetray 08-09-2008 12:10 AM
RE: Is this correct about charging Lipo's
Robert -
You are exactly right in your calculations.
For a 3300 mAh pack, a 1C charge rate is 3.3A. If you want to charge at 85% of the maximum rate, that would be 2.8A.
- Jeff
UH60 Crewdog 08-17-2008 03:43 PM
Hey everyone, Again...
What is the voltage not to go below and the not to exceed per cell?
jdetray 08-17-2008 07:33 PM
Don't go below 3.0V per cell under load. If you want the maximum performance and life span, don't go below 3.2 or 3.3V per cell.
Don't go above 4.2V per cell.
- Jeff
BarracudaHockey 08-18-2008 08:37 AM
The rule of thumb is you don't want to put back more than 80 percent of the capacity of the battery
