RCU Forums
-   Electric Training (https://www.rcuniverse.com/forum/electric-training-102/)
-   -   DX5e settings reset (https://www.rcuniverse.com/forum/electric-training-102/8782139-dx5e-settings-reset.html)
Switch_639 05-19-2009 01:58 PM
DX5e settings reset
how do I reset all settings on the remote? is there like a reset button or what can I do?
richg99 05-19-2009 07:11 PM
RE: DX5e settings reset
I don't believe that there are any settings to reset on the Dx5e. </p>
 The servo reversals are all by slide switches; the hi-low  "rates" are fixed at 70-100.  There isn't any provision for "throw distance".   You have to re-bind with any additional receivers.  You can use the first receiver over and over again, as long as you remember to reset the servo reversal setups to the newer plane. What is left??  regards, Rich</p>
richg99 05-19-2009 07:13 PM
Oh, if by "remote" you mean the receiver...then there aren't any switches on it.  Rich
Switch_639 05-20-2009 12:28 AM
the trims I want to know how to reset them to centre...
richg99 05-20-2009 07:14 AM
I don't know...but...I'd just count the audible clicks and leave them at a half-point.  I think we only get ten up or ten down, but I am not sure of that number.   Rich
-pkh- 05-31-2009 07:31 AM
The DX5e has a long audible beep for center trim, and for the left &amp; right trim limits. If you try the rudder trim for example, if you press and hold it left (from center trim) you'll hear several beeps going higher in tone until it stops at a longer high tone beep. This is your far left trim limit. If you release the trim button and push it left again, you will hear no more beeps since you are at the left limit. Next push and hold the rudder trim right, and you'll hear several beeps going down in tone until it stops at longer beep. This is your center trim point. If you release the trim button and push it right again, you'll hear several beeps going lower in tone until it stops at a longer low tone beep. This is your far right trim limit. If you release the trim button and push it right again, you'll hear no more beeps since you are already at the right limit.
Once you try this a few times, the beep tone feedback makes it pretty easy to figure out when you're at center trim.
Alpha205 12-31-2010 07:01 AM
This was really a helpful post. I am new at this hobby and have a DX5e. I was looking for help on how to control the digital trims and you answered my questions. This should have been more fully explained in the Owners Manual.
-pkh- 12-31-2010 07:13 PM
ORIGINAL: Alpha205
Welome to the forums! Glad this was helpful.
The DX5e is pretty basic, but it will get the job done. I got mine with an RTF Radian Sailplane, but quickly swapped it out for my DX6i. My DX5e is now set up to control my Nirvana Sailboat.
oldpilot2 03-01-2011 10:54 AM
Thank you pkh. I just bought a DX5e and you pricisely answered my question.
