flight idle?
Im new to electric so this may be a elementry question but. I purchased a Eagle 580 50" EP (Matt Chapman) and it flies great but I dont like its glide ratio when the throttle is chopped it drops like a rock. Is it common to throw a mix in off a switch or dial and have a flight Idle position?
RE: flight idle?
I set the throttle trim on my electrics to keep the propeller moving at low stick, usually to where the ESC just makes the motor work and no higher.
RE: flight idle?
I have no idle position on my any of my planes. Off is off. If I want some throttle, I just move the stick. Idle is an IC concept because you can't turn the motor off. There is no place for it in electrics.
Actually an "idle" motor, turning slowly actually induces drag which will just make the plane drop faster. Leave the concept of Idle for your glow planes. |
RE: flight idle?
Exactly I use it to get some of my faster planes to slow down, if your plane is dropping then you need to add throttle regardless of whether its at a complete stop or windmilling.
RE: flight idle?
ORIGINAL: tripower222 .....it flies great but I dont like its glide ratio when the throttle is chopped it drops like a rock. http://www.rcuniverse.com/magazine/a...rticle_id=1121 Nose heaviness may be the cause of your situation; how does it fly inverted when the throttle is chopped? |
RE: flight idle?
If you do want good gldier performance, if your ESC has a brake, setthe brake. A windmilling prop acts like an air brake. Stop the prop and you greatly decrease the drag. </p> |
RE: flight idle?
Yes, I was very surprised by how much drag a windmilling or slow-turning prop induces. My light planes glide much better with the motor completely off and fully braked. Try some dead-stick approaches and see if you notice any improvement in the glide. I suppose it would matter less with a heavier plane.
RE: flight idle?
I disagree on two points made. I am new to this too, so please tell me if I am wrong!
1) Idling increases drag and has no place in electrics 2) Using the break to stop the prop will add to the gliding performance of the airplane Having an idle RPM is beneficial in many maneuvers, such as snaps and stall turns. The prop wash over the tail will help the plane through these maneuvers. Full scale planes have an idle RPM and use that to their advantage in many instances. Of course there are times when the idle RPM can be a negative thing, such as trying to land on a short field. The beauty of electric flight is that we have full control of this throughout the flight. In precision aerobatics, we use the break function to slow the plane down on down lines, when gravity is trying to accelerate the plane in a vertical dive, or a similar attitude. If you want to the plane to glide, you want to turn off the break function and let the propeller spin naturally with the wind. Any force you apply in resistance to that natural spinning of the prop will work against the forward motion of the airplane. I just started flying my electric pattern plane. I tried with the break on at first, as it was suggested in the forums related to my airplane. While it really does slow the plane down in a vertical dive, or coming down the back side of a loop, it also slows the plane down when gliding through the air. It was later suggested to me to leave an idle rpm until I got used to the feel of the plane and of electric flight, then I could start playing with no idle and playing with the break. Subsequent flights have really given me the benefit of flying the plane in a manner that I'm used to, and getting to learn the characteristics of the plane before having to learn the characteristics of electric flight. |
RE: flight idle?
ORIGINAL: gaRCfield ...With an electric motor without the break set, the propeller is free to spin up faster since there is no compression holding it back, and thus the windmilling propeller is not creating any drag. The same process is at work in helicopter auto rotation which allows for a soft landing in the event of engine failure. Helicopters have a free-wheeling unit that effectively disconnects the blades from the motor if it should fail and allows the blades to spin up and create enough lift to allow for a controlled, soft landing. If the blades were inhibited by the engine compression and transmission, it would fall like a brick. |
RE: flight idle?
That's right, it does have more drag with the prop freewheeling. If it is slowing the plane down to much, crank up the throttle a bit till you get that glide speed that you want for decent approach, just above stall speed. Use your throttle as an elevator control.
| All times are GMT -8. The time now is 07:33 AM. |
