Startting glow or gas ?
Im getting confused with all the videos of people starting thier nitro or gas powered plane with thier hand . I've cut my finger couple months ago with my first nitro plane being careless . How do those guys do it with out cutting thier fingers in pieces ?
NY
RE: Startting glow or gas ?
Like most things, it takes practice!
personally I either use a chicken stick or an electric starter as I don't care to try my luck with fingers directly against the prop.
Bill S.
Bill S.
Yeah that first kickback or finger in the prop, teaches you what NOT to do!
Don't learn the hard way... as many of us have... a chicken stick or electric starter is best.
I prefer a self contained starter.
GA
ORIGINAL: Propworn
This works for me, I also use a self contained electric starter.
[youtube]http://www.youtube.com/watch?v=tE1oa0zC3bE[/youtube]
My Feedback: (12)
Still, that method is good when you can see/feel the carb, sometimes w some cowls the carb is out of reach.
An electric starter or chicken stick will save your precoius fingers. Even better go electric, you will never have to touch the prop
CA
Aww now that's no way to encourage somebody to step up the level of modeling experience required to do more than plug in a battery and push the left stick up to the stop! [:'(]
The best thing to do is come up with the starting method that works best for you. Some of my engines readily start with a simple backflip of the prop on the compression stroke, while others just need the zing of a starter to get them going easier.
Good for you for enhancing your modeling experience with something that burns more than electrons!
ORIGINAL: lopflyers
That one kick back is indeed a good teacher! After my hit, I use a 3/4 inch piece of PVC pipe and it works very well on the gasser. Still use a small electric starter on the glow engines.
Sorry guys i was'nt talking about kick backs on fourstrkes i was taking the mickey out of so called safe electrics,the whole banana re lips,unexpected bush fires and new years day fireworks.Plus those leccy motors are live all the time like an ex missus they can start up any ole time.
My Feedback: (8)
CA
If you use a plastic prop, it will be very sharp on the trailing edge. I sand those trailing edges so they won't cut. When you are at one with your engine as I am with mine I always use my fingers to start the engine. If it kicks back, your engine is usually flooded. I always pull the prop through to feel how the engine is, I don't just flip and get bit. Now stop bothering me.
I agree with many posts here.
Fingers are best used to build or fly planes. To start IC engines use a chicken stick or electric starter.
I recently purchased a Sullivan Dynatron and I am not looking back.
