Go Back  RCU Forums > RC Airplanes > Electrics to Glow Conversions
Reload this Page >
Wing Dragon - electric to glow conversion
Electrics to Glow Conversions Are you converting an electric airplane to glow and need help? Have you already converted an airplane and you want to show it off and give some tips? This is your forum. Enjoy.
Old 01-16-2006, 11:00 PM
Gravityisnotmyfriend
Gravityisnotmyfriend's Avatar
Default Wing Dragon - electric to glow conversion
I've had this Wing Dragon for a couple of years. I don't think you could find a better plane for the price. I've charged the flight battery so much that it will barely hold a charge anymore. I guess the sensible thing to do would to just buy a new battery - I guess I can't just leave well enough alone. My original plan was to simply swap out the motor with a glow engine and keep it as a pusher. I ran into two problems with this setup. First, the engine had to be mounted farther back otherwise there would be no air going over the cylinder and I fear it would over-heat. The second problem is that I am taking out the heavy battery that is mounted at the very front of the plane. These problems lead to a very tail heavy situation. The only way I could get it to balance without adding a bunch of weight is to mount the engine where I have. I would've much rather had a pusher, but it still looks pretty cool. I'll post a flight report as soon as the weather cooperates - but there's no reason to believe I'll have any problems with this setup.
ID:	389304   Click image for larger version
Old 01-20-2006, 08:43 PM
Default RE: Wing Dragon - electric to glow conversion
I test flew the Wing Dragon and I have almost nothing to say about it. It pretty much flew how I imagined a .061 powered Wing Dragon would fly. Short story shorter, it flew great. It was faster and had a better climb rate than the electric version. The most fun I had was doing touch and goes on our grass runway - something that the electric version simply wouldn't do. My only complaint was that the plane got really messy by the end of the day. I built an exhaust divereter out of a piece of 1/4" fuel tubing. I realize that this will probably rob some of the power, but I think it's worth it.
Old 01-20-2006, 08:56 PM
mclintock
mclintock's Avatar
That's what I like to see, electric to glow! It's cool to see the hunks missing out of the wings..
Old 01-21-2006, 02:55 PM
The hunks were taken out of the wing when it was electric. On hard "landings", the wing could shift and come in contact with the prop. The newer version of these has plastic pieces that protect that part of the wing. Yeah, I'm doing my part to eradicate those pesky electric planes. One more down
Old 01-21-2006, 03:59 PM
combatpigg
combatpigg's Avatar
That's nice when you can come up with a solution that is win/win/win. The oil on the plane is no big deal, it will protect the foam from harmfull UV rays .
Old 01-21-2006, 05:56 PM
bigchap
now i know what i am going to do with the beat up old easystar in my shed!
Old 01-23-2006, 03:23 PM
The whole conversion only took a couple of a hours. It would 've been quicker if I would have put the engine in the right place the first time. I think the easystar would be a great plane for this conversion. I'd reccomend a throttled .061 - they're only about $40. Post some piccs when you get it done
