Electrics to Glow Conversions Are you converting an electric airplane to glow and need help? Have you already converted an airplane and you want to show it off and give some tips? This is your forum. Enjoy.
Super Senorita ARF
Old 06-29-2010, 05:23 PM
Default Super Senorita ARF
I picked up a Senorita from Nitro Planes and noted that this version is set up as electric. I have a .36 TT Pro from another project and really wanted to use it with the Senorita. Will this work? What reinforcements or modifications would be necessary to prepare the airframe for glow? I am not very experienced and do not know if the plane can handle the glow vibrations and torque. The construction on this 63" version looks good and undamaged. Also, any suggestions on converting this plane to a tail dragger? Thanks, Mac
Old 07-04-2010, 05:26 PM
Bipe Flyer's Avatar
Default RE: Super Senorita ARF
This is about the easiest electric to glow conversion because the Seniorita was originally designed for .15 to .25 glow engine - the electric version has the same construction with the addition of ailerons. Fuel proofing the firewall is about the only modification you'll need to make to convert to glow.
Electric - http://www.sigmfg.com/IndexText/SIGRC60ARF.html
Glow - http://www.sigmfg.com/IndexText/SIGRC60.html
SIG uses the same video for both versions on their website.
To convert to a taildragger, move the mains to about 1" behind the LE of the wing and add a tailwheel.
Old 07-04-2010, 07:55 PM
Bipe Flyer,
Thanks for taking the time to pass on the information. Much appreciated. Mac
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
