Prop'r Prop size question
I'm putting together a Seagull T6-A Texan II with an E-90 brushless electric motor and matching 90 amp ESCI was thinking about ganging up two 11.1v 3200 mahlipos, but still haven't quite figured that one out....anyway, the question is this: What size 3-bladed prop would be appropriate (if any), the full scale aircraft sports four blades, but Im pretty sure that isn't do-able at this scale. Common sense RC has the following chart for the motor, but it seems to be only for standard props. Can anyone help me out? I'm more of a glow guy and I don't want to screw this up! Thanks!! http://www.commonsenserc.com/product...roducts_id=422<-Link to the chart***</p> |
RE: Prop'r Prop size question
Don't screw it up! Make sure you put the fuel tank in right side up.
Did you know that we chew up and spit out anyone who talks electric around here? THIS IS THE ELECTRIC TO GLOW FORUM! |
| All times are GMT -8. The time now is 12:11 PM. |
