ESC Brushless and prop 101 please help
how do I choose the right ESC and brushless motor? I want to have an esc that will not overheat and I also want a motor that will provide more than enough power to make my glider climb with some extra weight on it.
my glider is 77" and it has about 20oz worth of equipment (this includes 3000mah lipo) How do I choose the right prop for the motor/esc combination. Is there a chart somewhere like the glow motors have to choose the right prop? |
RE: ESC Brushless and prop 101 please help
You might want to try the electric forum, rather than this forum about how to not use electric engines...
ORIGINAL: Mr Cox You might want to try the electric forum, rather than this forum about how to not use electric engines... SACRILEGE!!!!!!!!!! Changing over from electric to a gas guzzling, smoke spewing, slimer. :D uavflyer76, there is no such animal per say on comparing gas to electric. It's more dependent on what you want and need to decide on an electric power plant. If you can't get help over on the Electric side, stop over here. www.badiusownersclub.com/forum2 Someone there will be glad to help you out. We convert evil gassers to electric all the time there. ;) |
| All times are GMT -8. The time now is 07:36 PM. |
