Employment, Jobs, Help Wanted in Radio Control Industry List your ad free for help wanted in the rc industry here. If you are seeking a job in the rc industry post your resume or other information as applicable here.
I do Model A/C Plans and Parts.
Old 07-11-2007, 09:56 AM
CoosBayLumber
Default I do Model A/C Plans and Parts.
If you are thinking of developing a small Model Aircraft based business and need a CAD based plan or part files for laser cutting, then go to
http://www.mybloo.com/coosbay/laser/projects.htm
and see an extensive listing of completed projects for customers.
Young or old, have aided in the startup of several home based firms since the late 1970's. Glow power, electric power, Ducted fan, Old Timer, Aerobatic, glider, of 28 inch W.S. to 128 inch W.S. Work is generated from your prototype or sketches, and plotted out here using Autocad by Autodesk.
No, cannot show you a sample work, for that belongs to the customer. By going to the web site noted below, you can however download a one sheet example of a project done several years back. Most everything is generally handled via Internet, at your pace. Use the MAILBOX button to get ahold of me.
William
Old 07-28-2007, 06:19 PM
ByLoudDesign
ByLoudDesign's Avatar
Default RE: I do Model A/C Plans and Parts.
YOUR LINK IS NO GOOD MY FRIEND!
Old 09-14-2007, 10:26 AM
CoosBayLumber
Default RE: <br> I do Model A/C Plans and Parts.
Need to revise the URL extension only. Use the URL as per address otherwise.
http://www.mybloo.com/coosbay/laser/laser.html
Wm.
Old 10-07-2007, 06:06 PM
SomeSailor
I also cut kits and parts on a cnc laser. If anyone is interested in getting a kit or parts cut, shoot me a line.
I've done a great deal of cutting for a local UAV designer and as things slow down this winter and he goes into build mode, I'll have some time available on the laser here. I'll match anyone's rate within reason.
Shoot me an email: Mike [email protected]
Old 05-20-2008, 06:00 AM
TheRCShack
My Feedback: (27)
If it is fully rotaitonal I may be able to use you to take some of our work load off.We are behind due to a purchase of another company and also a new contract is forcing us for new equiptment and a operator.I already have the code depending what you have if not I have a converter that drinks alot of coffie but he is fast.You would need to sign a non disclosure contract for each part that is enforced by the manufactuer.Also clean background they will check.PM me lets talk.Leave a number and also all your equiptment details ,years made and model #s and your abilities. Also details on your shop and also do you have lic and TX Id number and how long?Can you subcontract etc?Also would need references or solid previous work history as a machinist.
