76cc husky, prop hub
Hey guys ! I'm looking for someone that can make a hub for my 76cc husqavarna Engine. (clutch side ) Not in a rush, just trying to find someone
Thanks Jet
Thanks Jet
Jet, can you take a close-up photo of the shaft where you want your new hub to be attached. Also maybe make a drawing with dimensions for the new hub you want. That would be a great help.
Hello Captn ! Can you help me ??
Yes, I sent an email, but got no reply ... I think I can hold off for a few more weeks :-) I'm still building the hull anyway.. That would be awesome if you could make one for me
As viewed from the end of shaft, what is the direction of rotation? Also is there a place for a key-way cut in the un-threaded part of the shaft? Is this for a boat?
The rotation is clock wise if your looking at the shaft from the rear. Yes this engine is for an Rc airboat, thats why I need the hub on the clutch side of the engine. In this configuration I can run tractor props
I think there would be room to cut a keyway in the un threaded part ... there is 2 different flat surfaces that could have one. I can measure them when I get home
