Walbro Membranes on Zama Carb can it be done?
Hello everyone.
I have been trying for two weeks now to fly a BME .90 and i havent been able even to make it fire.
It has a Zama Carb on it, and i suspect the membrane doesnt work
Can I use a Walbro Membrane on my Zama carb?
Ive measured then and they are practically identical only difference is Walbro is squared and Zama has one corner modified.
I understand it would be much easier to find a zama replacement kit but in México that is not easy business.
Any advice will be very much appreciated.
Thank you both very much.
I was able to find a zama distributor here in México and found the right diaprhagm
I´ll try to fire it up this weekend,
Regards.
Oddy
Regards.
Oddy
