Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Engine Conversions
Reload this Page >
Electronic solutions to modifying glow engines of all sizes to gasoline
Old 07-13-2022, 04:24 PM
  #126
Cat 1
Cat 1's Avatar
Originally Posted by 1967brutus
Posting this for Rob.M, because he does not yet have the possibility to link pics or vids:
If the links won't work, I'll figure something out...
https://www.youtube.com/watch?v=G9ZnHzLDWPU
This is yet without airbleed. Rob has flown it, and reports excellent behaviour in the air, and good adjustability of the fuel curve, BUT, same like Chris, a slight irregular idle, so his next step will be a tiny airbleed hole to see what happens.
Having given this a bit of thought, I think, that this irregular idle is caused by the pretty low fuel opening values of the curve: the solenoid is open for a very short amount of the total time, and due to its fixed frequency while the engine runs "whatever it likes to run" some valve openings are in the middle of the induction stroke, others are while the induction port is closed, and some induction strokes occur with fuel supply, others without, resulting in a varying mixture strength in the buffered mixture in the crankcase (at idle, it is my estimate that the total refreshment rate of the crankcase volume is less than once per 10 revolutions so when supply is intermittent, that leads to varying average mixture strength).
The use of either an LS needle OR an airbleed will force the fuel curve upwards, which causes the solenoid to be open for a larger percentage of time, reducing this effect.
Anyway, whenever Rob has time, I think I'll have a few 2-strokes that could do with a new carburettor
What is nice to see, is that also THIS idea, is repeatable by others, and for that, a big thumbs up to Chris, and just as big to Rob for proving that.
I love seeing these developments, and I an sentenced to spending a month on a ship in the gnawing knowledge that when I come home, there will be a plane at the clubfield that I am going to be "slightly jealous" of...
WOW!!!!WOW!!!! - Only thing more exciting than having my own carb work is actually seeing another one work!!! Bravo Rob!!!
I agree with Bert that the idle issue is caused by the low "duty cycle" of the solenoid at idle - The air bleed made an immediate improvement on mine but I think its still a item to be worked at - Would like to try a "oblong" hole on the top of the barrel - Rob's issue at idle sounded exactly like mine.
When I get time I might also try a "Slide Barrel" style carb. - Have also considered the thought mentioned previously with an "Air valve" with a fuel injection point after the air metering (Webra dynamix was like this) but I think the "suction" might cause issues as we see with the fixed jet carb of excessive idle fuel flow requiring a very low open pulse on the solenoid. I think a slide carb could be made with "cutouts" like a round slide Mikuni to correct the idle suction and flow and would still offer a better "Venturi" area than a barrel carb.
Old 07-13-2022, 07:38 PM
  #127
Cat 1
Cat 1's Avatar
Bert and Rob...
On the air bleed addition - here is the issue with the one noted in my "revisions" I sent - It does get the idle setting off the bottom but its effect goes away quickly off idle - Can be seen by the dip heading to mid range. I think an "asymmetric barrel hole"
might work better.
Old 07-13-2022, 08:37 PM
  #128
John_M_
John_M_'s Avatar
That's one of the reasons I would like to try PFM, over PWM, Pulse frequency increases / decreases, rather than duty cycle. should provide improved control over fuel flow at idle, low rpms.
What happened with the cline regulator knock off, that will change how fuel is metered through the carb.
Old 07-13-2022, 10:24 PM
  #129
1967brutus
Originally Posted by cmulder
There is nothing in those forum rules that the first 10 (?) post have to make sence.
Post about the weather or what desert you had for dinner.. No one here is going to complain
just a thought (and another post to inflate my stats
Nah... he's not the type of guy doing that...
Old 07-13-2022, 10:34 PM
  #130
1967brutus
Originally Posted by Cat 1
Bert and Rob...
might work better.
The LS needle carbs show a similar shape of curve, at least, most of mine do. That has so far never shown to be a problem.
The biggest issue is that at low RPM, there is not much kinetic energy in the system (the mechanical side of it, the moving parts) which make small irregularities pretty noticable.
With the tech availlable, not much to be done about that electronically, and solving it by means of an airbleed or asymetric throttle bore might turn out to be fairly critical and engine specific because of lack of adjustability.
I would think an asymetric bore of the throttle body might be a good solution and perhaps a slightly tapered bore of the barrel might prove to have general better behaviour overall. The trouble is: there is only one way of determining the needed assymetry or taper and that is empirical.
I would hope for something more user adjustable to maintain the "onesizefitsallability"...
Reality for me however is: If I put my heart into it, I can get an engine to idle indefinitely on the ground. No probs and not even a solenoid needed. Lookey here...
I mean, that is .52 fourstroke tuckering away indefiniteley at 1700 RPM, on gasoline, 6 years ago and no solenoid yet... The trouble was that it would not respond well to throttle when tuned like that.
I found that a nice idle on the ground, well, it is nice, but it is not what you necessarily need in the air.
Most of my planes, on the ground I need to "help them a bit" (run a slightly elevated idle) to keep the fire going, but in the air they simply don't quit, no matter what I do.
I would in general advise to tune for flight, not for the ground, and before any adaptations are going to be made, first work out how it functions in the air, because it might turn out that what is done to improve idle on the ground, works out negative in the air...
Old 07-14-2022, 12:58 AM
  #131
hmeijdam
can you elaborate a bit more how changing the pulse frequency would result in a mixture change?
For example: If the solenoid works at 50% dutycycle at 30Hz, and I would change the frequency to 20Hz without changing the dutycycle, do you anticipate a mixture change?
In April 2019 Bert did some tests with a custom made solenoid driver, where I added an extra potmeter, so that Bert could also change the pulse frequency. That was however on a prototype driver with only 40 steps resolution. In the end we decided that increasing the resolution was the way forward and did not experiment further with frequency changes on later revisions of the driver.
Old 07-14-2022, 03:41 AM
  #132
1967brutus
I can elaborate a bit more on that: At high RPMs, reducing the PRF while maintaining dutycycle (so, the same amount of fuel, just divided in larger or smaller drops) showed a more irregular running and the engine RPM started to audibly fluctuate at somewhere around 15Hz. The PRF became so to speak noticable in the exhaust note. If memory serves me properly, I seem to remember that from 30 to 25 no change whatsoever, from 25 to 20 a slight change, but more a "feeling of a change" than anything else, at 20Hz the change would be undenyable and at 15 Hz the RPM would clearly fluctuate at the rythm of the PRF.
At low RPM, the engine simply became erratic at lower PRF. No oscillating RPM or anything, just erratic.
Back then, I was told by a Stihl mechanic, that Stihl used 30Hz as fixed driving frequency for the solenoid, and from that I assumed that the limit of how fast the valve can move would be not too far above that, so I never tested with higher frequencies as I saw no point in bumping my head against an invisible wall that Stihl allready determined to be there.
I could not tell any difference between 25 and 30 Hz, and had reasons to believe that there would be no improvement at frequencies above that, all the way up to where the valve would be unable to keep up. So I left it at that.
Of course, anybody is free to test and experiment, I mean, you guys are probably all more than capable enough to program higher frequencies in your driver. I just never saw the point. I am allready flying without issues for about 3 years now when it comes to adjustability.
In those three years there have been 3 distinct steps:
1) the change from a 2,5% resolution to a 0,025% resolution. That made a HUGE difference in adjustability
Dave then suggested active temp and pressure control and at first I did not see much in that since I was flying without issues uncorrected. But since the idea kept returning, I did
2) tests with a temperature correction that showed that active corrections really could make a difference
So both Hans and Dave started to work on that, and that resulted in
3) full press/temp correction, which simply works like a charm.
Anything beyond that, I have the feeling will go beyond most peoples capabilities for adjustment and stop being suitable for the target group of users.
The improvements as we see with Chris' thottle body design are a different step. I am wildly enthousiastic about that.
The issue is that making something like that is not given for everybody, but if they would ever become availlable, that would be a REAL step forward.
I might be able to set up a limited series production, but I am pretty sure it ain't going to be cheap. I don't even dare give an estimate, doubtful if I can keep it below 100 bucks and since I have literally zero clues of how many would sell, I am not going to do that.
I mean, right now a run of 50 solenoid housings cost me about 750 bucks out of pocket and the previous run took me 18 months to sell. That was a one-fits-all. Throttle bodies need to be sized to engine, which means that becomes totally unpredictable for me.
I don't know how to solve that puzzle, or I would.
I wish it were different....
Old 07-14-2022, 05:17 AM
  #133
cmulder
Lightbulb plastic carb body?
one thing i would like to try is 3d print a simplefied carburator body design.
The perry carbs hav a plastic body so its not a new thing.
One way to get around tolerance issues is to print the holes slightly undersized and then drill them out to size.
Also would a stock print nozzle as spay opening be possible if the shape of the hole its located in accounts for the blocking of the air flow by the nozzle.
Anyone here who enjoys drawing cad? the design used by that cox trottle might be a good start to see if it could be done.
TheEdge (07-14-2022)
Old 07-14-2022, 05:24 AM
  #134
1967brutus
If a 3D printed carb would work, that would be an excellent solution. But my gutfeeling says that even then you can't get around a metal throttle barrel, and the precision boring of the holes still remains an issue.
Old 07-14-2022, 05:48 AM
  #135
Cat 1
Cat 1's Avatar
I can CAD and print but I don't think my "process" would hold up to the demands of carb body - The body is actually not that hard a peice to produce once the design is established... Mine was done on simple manual machines with no "tricks" other than one simple mandrel for one of the operations. I think variability could be taken care of with jet and barrel changes but mounting is different on many engines and that's a bigger hurdle I think.
On the question earlier on the clone regulator - It is sitting on my bench waiting for final attention - crazy busy summer here and its fallen down the priority list... Finally got a few planes in the air and they keep "snagging" on me and taking up my shop time with repairs. Last week my stone cold reliable "wren 44 turbine" decided that a bearing had had enough of the "200K RPM game" and started making funny noises on rundown. The one consistent runner has been the Kavalier with the Gas converted ST.45.. still a work in progress with tweaking but it just runs...
Old 07-14-2022, 06:26 AM
  #136
1967brutus
I hate to say I told you so, but... I told you so...
Just kidding, snagged planes are always nasty, but I can assure you, once you got things down to stable settings, those little gassers will just fly and fly and fly.
Old 07-14-2022, 06:29 AM
  #137
1967brutus
Just a general question to you and also Rob: How many hours did you guys spend fabricating the body and barrel?
Old 07-14-2022, 08:41 AM
  #138
Rob.m
Bert.
the milling time for me on the 5 axis milling cutter was a total of 25 min. the rest was turned by hand and only the square hole in the gas valve was milled and was 4 min. programming the housing took about 2 hours, all in all, to get a complete product, it takes me about 4 to 6 hours of work.
Old 07-14-2022, 09:32 AM
  #139
John_M_
John_M_'s Avatar
With pulse frequency modulation, the pulse rate is changed, and the duty cycle becomes variable based on the pulse rate. The faster the pulse rate, the less fuel that will pass, and the slower the pulse rate more fuel will pass. In PWM, the pulse frequency is fixed at 30 hz, and the duty cycle / on time is changed, Where as with PFM, the pulse rate is changed and the duty cycle changes as the result of the change in pulse rate,
Old 07-14-2022, 09:33 AM
  #140
1967brutus
Originally Posted by Rob.m
Bert.
So... assuming the programming remains the same or only minor changes for different engines, if I understand this correct, making a new one with the existing program is about 2~4 hours of work?
Just trying to get an idea of what it might take to make limited series...
Old 07-14-2022, 09:58 AM
  #141
John_M_
John_M_'s Avatar
With a 5 axis CnC, once programed, its just a matter of loading the stock, It is a relentless machine that will do that same process over and over until either you run out of stock, something breaks, or wears out..... unless its a manual 5 axis mill, then you are back to old school machining methods.
We have 3 of these running producing cylinder heads and blocks, 2 A560's for cylinder heads, and an XL for blocks & heads.
https://www.centroidperformanceracin...ad_porting.php
Old 07-14-2022, 10:14 AM
  #142
1967brutus
With pulse frequency modulation, the pulse rate is changed, and the duty cycle becomes variable based on the pulse rate. The faster the pulse rate, the less fuel that will pass, and the slower the pulse rate more fuel pass. In PWM, the pulse frequency is fixed at 30 hz, and the duty cycle / on time is changed, Where as with PFM, the pulse rate is changed and the duty cycle changes as the result of the change in pulse rate,
It might work, but I would not think all that much better. Because the solenoid is not very fast. I don't know HOW fast exactly, but if I had to venture a guess, I'd say 50 Hz at best. Which would mean a "closed time" of 0,02 sec in order to have the valve fully closed at 50Hz.
Anything faster than that might result in a treshold for opening from fully closed. If it cannot manage 50Hz, the fixed Closed-time needs to be longer.
But even if it were 50 Hz, that would mean that to get 90% of fuel passage (in order to have headroom for temperature and pressure corrections) frequency would need to be 5Hz or so. That frequency will be VERY noticable as a 5 Hz "jitter" in the engine RPM.
For a smooth engine run at WOT, you would have to limit the frequency range to a downward limit of 25 Hz. It could be very possible, but I don't think you will get "better" results to be honest. I would expect more heat generation in the solenoid winding.
Old 07-14-2022, 10:47 AM
  #143
cmulder
Post cost will add up quickly
What are the cost to run a 5 axis cnc each hour? Including things like writeoff, maintenance cost, lifespan cutting bits, setup and electricity.
Add a reasonable wage for the operator, cost of packing shipping, order processing.
I would be verry surpriced if the price of a carb and electronics set would be less then €250.
There are many modelers who have no problem with spending this kind of money (cough turbines...) if it makes there planes fly better.
But you are basicly looking at starting a small company.
Comercial production does not have to contradict "open source" prusa for example is quite succesfull with there printers.
There design files are avaiable but its just cheaper to buy from then then to try to make the parts yourself.
Old 07-14-2022, 11:18 AM
  #144
John_M_
John_M_'s Avatar
You don't need the valve fully closed. you don't run an engine with the carb needle valve fully closed, all the solenoid is doing is replacing the needle valve and modulating the fuel mixture.
Old 07-14-2022, 11:23 AM
  #145
John_M_
John_M_'s Avatar
Just the 3 CnC's are over a million usd, I don't own or lease the facility, but the cost are recouped through sales of course. one pair of cylinder heads milled from billet, paid for the first CnC machine.
Old 07-14-2022, 11:32 AM
  #146
1967brutus
True, but it WOULD need to be able to close to about 5% of the WOT fuel passage, whatever that might be.... And with a fixed "closed-time" and a high PRF, that valve then would need to open and close awfully fast inbetween the fixed "closed-times", given that that "closed-time" would be 0,02 sec... the open time inbetween would then be something like 0,001 sec in order to be 5% of fully open, and even shorter if we use only 50% opening as WOT setting (which is needed to keep the PRF acceptable for WOT running, because anything below 15 Hz would result in audible RPM oscillation....).
There are technologies that make this possible (Piezo actuators)... but this solenoid is NOT one of those technologies.
And Piezo actuators are a whole different can of worms.
Old 07-14-2022, 01:22 PM
  #147
John_M_
John_M_'s Avatar
There is noticeable audible oscillation in Full blown EFI systems, not so much with direct injection, due to how the fuel mixture is calculated and delivered. In the old feedback carbs, and multi point injection systems, you can hear the engine go into closed loop in the exhaust note, and if the tachometer wasn't dampened, you would see that mixture oscillation in the tech readout as the fuel mixture swings across stoichiometric mixture.
Old 07-14-2022, 06:12 PM
  #148
Cat 1
Cat 1's Avatar
I would concur with Rob's estimation - I could probably build one on my Manual equipment (second time around) in 3-4 hours. Its not a complicated part but its still a part best done on automated tooling - I have done a few limited run projects on manual equipment and it quickly becomes tedious and monotonous and not worth the time investment. CNC changes everything as this should be a simple setup for a limited production run but not sure what that's worth nowadays.
Old 07-14-2022, 10:06 PM
  #149
1967brutus
Then I am not going to pursue that... Too many uncertainties.
Old 07-15-2022, 01:11 AM
  #150
1967brutus
That's the thing... I doubt this solenoid will do ANY "proportionality" pretty poorly. I simply doubt that will work.
As I hinted at before, if you would make a valve with a Piezo-actuator, now THOSE would do proportionality pretty accurately, have no heat generation and no wearing parts... BUT... they need fairly high voltages to actuate them, and there is to my knowledge nothing readymade on the market for this kind of application. That is a whole different can of worms.
