Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Engine Conversions
Electronic solutions to modifying glow engines of all sizes to gasoline >
Old 03-14-2023, 03:28 PM
  #1501
Default Walbro fuel pump return spring
For your reference, Dan.
Old 03-14-2023, 04:06 PM
  #1502
Rcplanedan's Avatar
thanks glowgeek
Old 03-14-2023, 05:14 PM
  #1503
Cat 1's Avatar
Originally Posted by 1967brutus
#Metoo...
Way I see it, fiston and running gear is 100% safe. We know that from earlier conversions. Leaves only the rotary valve, and it has all appearance that this particular construction is extremely easy to dismantle and inspect for wear every runhour until you are sure no bad stuff happens.
I would say, go for it, Chris!
Not that it took much persuading but im going to try - Took it apart and it has a bit of a lumpy front bearing - Will swap them out and then put it back and try gas - You are correct Bert I can pull the rotor out in 3 minutes to keep an eye on it ..
Old 03-14-2023, 05:25 PM
  #1504
Cat 1's Avatar
Found a Manual for the Webra T60. A unique entry says you can modify the "valve" timing by one notch ether way of alignment mark to "Increase Performance" - going from glow to gas would there be a preferred direction or would it solely depend on "prop load" and RPM.
Great effort on the various Carb experiments Dan.. Building the Knowledge base...
Old 03-15-2023, 12:01 AM
  #1505
If memory serves me correct, the timing of the "valves" has, together with length and diameter of in and exhaust tracts, some influence on where peak torque and output is on the RPM range. And now I have to go back to "hillbilly logic" but AFAIK, advancing the timing a bit would place peak torque lower on the RPM range, retarding it would bring it up higher.
This is mainly caused by the closing point of the intake: The inrushing fuel/air mixture, as well as the column of spent gas at the exhaust stroke have inertia, and by shifting the valve overlap period, as well as the closing point of the intake a bit later, this inertia can be used to improve cylinder filling at high RPM when there is not much time.
Advancing the timing will basically FORCE the peak torque and peak power to occur at a lower RPM.
Retarding the timing will improve absolute peak power by shifting peak torque to a higher RPM, but that will happen at the cost of decent low RPM behaviour. Advancing the timing will improve low RPM behaviour (not performance) at the cost of absolute peak power. The length of the intake tract also has influence on this, but I am not exacly sure which change does what, and where in the rev range that change will have effect.
But I do have a nice video where this effect is demonstrated: My Wankel has a very crude muffler originally, that does little for noise reduction and even less for performance, but simply adding a length of completely random and untuned tubing to the tailpipe. has a very significant effect on peak power of about 8~9%
For what it is worth, I would not tune the engine for high RPM (increased heat) and I would not tune it for low grunt either (higher loads on the conrod), I would leave timing original, because spark ignition on its own will allready increase the engines ability to swing larger props at lower RPM.
Old 03-15-2023, 03:58 AM
  #1506
Of course, Bert is correct.
We all played with cam timing quite a bit in my drag/road racing racing days, amateur-ish as we were. Advancing cam timing for peak torque at lower rpm, retarding for peak torque at higher rpm. Cam timing changes using higher duration cams has a more dramatic effect on performance than with stock cams; due to a greater change in cranking compression/dynamic compression ratio.
P/S, Listening to that Webra in the vid, it sounds like predetonation transitioning off idle. Could be the nitro content is too high, maybe bad needle adjustments, or maybe the cam timing is off too far. Don't know, but it doesn't sound happy throttling up. Makes me cringe.
If the Webra timing gears allow for a change in cam timing of +/- 6 degrees or less I might give it a try just to satisfy curiosity. Any more than that I would install in "straight up" and leave it alone.
Old 03-15-2023, 04:29 AM
  #1507
True... retiming the cam at best changes the RPM's where peak torque and peak power happen, and with some luck, shifting peak power to a higher RPM will maybe, possibly result in a bit higher peak output, but it comes with a severe penalty in "drivability at lower RPM.
Different cams are the only real solution if you really want to extract more power from the engine. Because advancing or retarding an existing cam changes both opening AND closing times, and that is never "optimal".
Old 03-15-2023, 04:35 AM
  #1508
I noticed that too, but in all fairness, I have at times searched for ages for similar sounds, that I finally identified as a rattle in my testbench, and these folding worktables are known for having a rattle here and there.
It could very well be that it detonates or pre-ignites (it sure sounds like it, no doubt), it is just hard to tell with this kind of testbeds.
Old 03-15-2023, 05:13 AM
  #1509
Cat 1's Avatar
As soon as i started reading Bert and Lonnie' s responses - it jogged my Memory on this subject.. on my 69 Camaro I remember running the cam Timing advanced.. It was the DZ 302 engine and had a copy of the "Stage 2" solid lifter camshaft. Being a short stroke - big bore version of the chevy small block it really liked to Rev. Running the cam advanced (variable keyway settings) made it more "street friendly" and restored some low end grunt. It still didn't really come alive until 4000 rpm though - but it helped. Funny how you forget stuff.
Got the bearings changed - was tough to pull the piston pin to remove the rod (one piece case) but got it.. Everything looks great inside and can tell it has very little runtime. Got a replacement prop driver almost done for the magnet mounting- so I can keep the "stock piece" intact.
Old 03-15-2023, 08:36 PM
  #1510
Cat 1's Avatar
Prop driver done. Might get to try a bit of “petrol” this weekend
Old 03-16-2023, 11:10 AM
  #1511
Banned
My Feedback: (788)
Default Recognition
That is some skillful work right there.
Cat 1 (03-16-2023)
Old 03-16-2023, 08:43 PM
  #1512
Cat 1's Avatar
Default Sorry to go😢
As much as it pains me to say this I must leave this group….. I have thought I could get along and not have it affect me that dramatically….. but I must go before any further suffering occurs.
I just Ty-Wrapped a sensor on. 🤣🤣🤣. ***!!!🤣
Can’t believe how well it worked and how well it holds. Tightens it a bit to much and had a heck of a time adjusting the timing!!!!
Old 03-16-2023, 10:00 PM
  #1513
I hate to say I told you so...
with exception of the radial and the Wankel, ALL my engines hav tie-rapped sensors...
Welcome to the dark side!
Old 03-16-2023, 10:17 PM
  #1514
Rcplanedan's Avatar
Cat1 great job..its ready to go
Look forward to see it running..
Got my twin ignition for the asp ft160..time to rig it up and see what happens..im still thinking to try the sto k carb ..i tried the stock carb on the fs91 no hope of running..infact i now know why i had a tough time tuning that engine on glow to begin..hs needle has to be wound out 2 turns before fuel can pass it and ls needle problematic..well i may just stick with the saito gas carb it works just fine
Old 03-16-2023, 11:49 PM
  #1515
This is an FT160, 100% stock except for the exhausts, running on gasoline.
It literally was its first run here so there is not very much WOT running in the vid.
It looks like it is running beautiful, innit? But this is what my main issue is with all those vids from Morris: if you cannot see the throttle movement, you cannot judge its throttle response, and I can guarantee that in this state it is basically "unflyable".
Sure, you can fly a plane with it (sufficient power, and it near 100% sure won't stall) but try dosing throttle for landing... It truly is horrible. And it is not because it was not yet adjusted from the box, it never got better until I modded the carb.
(This vid is also the LAST time EVER that I used gloves to start an engine, but that as an aside)
Old 03-17-2023, 12:05 AM
  #1516
Rcplanedan's Avatar
That surely looks likecit runs fairly wel bert ..
but i an see its not truly running well of throttle there ..it seems a bit off. And yeah new engine..and i wathched your video of throttle mod.bad lighting but i understandwhat you were showing... .i got a pair of asp fs80 mufflers with my engine..well the exhaust is slapped together for its run tomorrow..il just use the fg arb ..i know i can get a tune with it..
Old 03-17-2023, 12:23 AM
  #1517
The throttle mod works by changing the shape of the guide groove, then compensating the LS needle for it to bring idle back in range. the result is that Idle (after compensating the LS needle) remains the same, WOT remains the same because it is not affected by the grinding, but midrange gets leaner because of the shallower angle of the guide groove in the first half of the throttle stroke.
This mod works OK on the FT160, but you have to be a bit careful, it only needs a little bit of grinding (compared to singles).
I think that this is caused by uneven mixture distribution, and leaning out midrange too much will cause the leanest cylinder to drop.
Getting the distribution more even can be done in a similar way as what I did with my Radial (the tiny airholes) but I have the feeling that unlike the radial, on the FT160 this solution is very sensitive to dirt due to the location of the carburettor. I opted for a tiny "spoiler" in the intake instead.
Old 03-17-2023, 12:43 AM
  #1518
Rcplanedan's Avatar
Wow..would definitely have to be careful on the die grinder to take a small amount off the groove..well im going forward with gas conversion anyway..so i will give its carb a shot ..with a little bit of are ..i may manage it😆
Old 03-17-2023, 02:32 AM
  #1519
Rcplanedan's Avatar
ignition setup ..ready to put on the bench for a run tomorrow
Old 03-17-2023, 02:48 AM
  #1520
Yeah, the first time you take the grinder to a carb, definitely feels a bit uncanny.
In general, if you remove about half the thickness of a standard Dremel cutting disc off the low end, and make the cut a bit "rounded" to by and large 1/2 of the total stroke, that is a good beginning for a single.
Just start carefully and gradually increase after testing. Do NOT go all the way on the testbench, because you cannot "ungrind", and engines need a bit more fuel in the air than they do on the ground, but it is not very critical. After I did about three carbs, I could basically do them freehand and end up near spot on.
A pic to give you an idea of how the final result should look, give or take...
ASP FS52. The original slot is milled therefore ends abruptly, it is unvoidable to cut a bit beyond the end, because the side of the slot needs to be ground to full depth.
It does not affect functioning of the carb or the throttle movement.
Old 03-17-2023, 02:49 AM
  #1521
Neato!
Old 03-17-2023, 03:20 AM
  #1522
Raleighcopter's Avatar
And you have a printer and abs filament too. My god, man. What is wrong with you.
Old 03-17-2023, 03:21 AM
  #1523
Rcplanedan's Avatar
That is perfectly clear to see👍
nice and easy with the dremel.
Old 03-17-2023, 04:21 AM
  #1524
Cat 1's Avatar
drank toooooo much kool-aid!!!!
Actually this is a printed holder. The wrap goes through a bolt hole and around. I think I will try a printed design actually made for a tie-wrap to be the fastening device. The wrap method actually strengthens the whole printed mount and does away with the bolting holes which are always the weak spot on a printed one
Old 03-17-2023, 05:51 AM
  #1525
no bolt holes on mine except the clamping bolt for the bracket. i pull the hall sensor out of the stock holder (actually, i never insert it into the stock holder) and place it into my custom sized bracket.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
