Echo SRM 200DB conversion
Old 11-20-2024 | 12:02 AM
Default Echo SRM 200DB conversion
Hi everyone, i present to you my conversion in progress of an echo srm200db brushcutter engine which is 21cc.
The magnetic plate has been replaced by an rcexcl electronic ignition with actually 30° of advance setting, the original WA59 carburetor was replaced by a slightly larger WT93A.
I now have to replace the ugly original exhaust which is too heavy and too restrictive.
And find the right carburetor settings because I hope to run this engine on E85.
For now, the weight is around 1.2kg, and i hope to be able to turn a 16x6 propeller at around 8000rpm.
Old 11-20-2024 | 05:12 PM
Lookin good! Did you make your own prop hub?
Im on the hunt for an echo myself. The gt225 is also 21cc.
Old 11-20-2024 | 10:13 PM
​​​​​​Yes, I have a lathe to do it. 20mm diameter on 30mm length, and 40mm diameter on 10mm length to interface with the prop.
Standard spark replaced by a cm6 with an adapter permit to reduce the length of the hub.
