33cc homelite
#276
ON, CANADA
RE: 33cc homelite
Either that or learn how to type a hell of a lot faster.Us "hunt and peck" types are REEEEEEL slow on the ole keyboard.And I thought it was geekish back in highschool to take "typing" as a course.Geesh!!Then again,who would have figured back in 1978 that most people would have a personal computer in their house and be chatting back and forth like this world wide?Isn't hind sight great!And to think I took belly dancing instead............
#277
My Feedback: (22)
RE: 33cc homelite
I was complaining to a friend at work a while back. I'd been typing so much my fingers were sore. He held up his right index finger and said "this puppy does the work of ten fingers!" I thought that was pretty cute. He was in a small car wreck a little while later. The only injury he sustained was when the airbag deployed. SUPERFINGER was broken. If you thought he typed slow before, you should have seen him with that cast on. He would tape a pencil, eraser down, to the splint and was back in business. Just shows you don't always know when you've got it good.
#278
RE: 33cc homelite
Way off topic here, but some interesting trivia...
The keyboard layout we have now is called the "Qwerty" system. It's called that because that's the top left row of keys. The system was invented long ago to actually slow down typists, as the old mechanical typewriters would jam up if you typed too fast. There are much better/faster layouts, scientifically proven, but nobody wants to change and learn all over again!
BTW, I've seen some wicked fast "hunt & peck" typists though.
Take care,
AV8TOR
Take care,
AV8TOR
#280
RE: 33cc homelite
You guys got me inspired by the fine work you have done with the 33 cc.After i get done with the Ultra Hots/Ryobi project i am gonna start on an Ultimate biplane for the Homelite 33.That should be fun!!!!Great little engine it seems,with alot of potential.
#281
RE: 33cc homelite
Turbobeaver,I would like to respond to you but I am unable to locate your "e" adress. If you will "e" mail me at [email protected] I will be glad to respond to any questions you might have and may be able to provide a resource to allow you to gain more knowledge. I have a company that eleminates noise in large computer and comercial grounding systems and have "headed up" many interference commities for the "ham radio" crowd sience abt. 1956. If I can get my wife Dr. Becky to type the answer for me at abt. 120 WPM error free I do much better. HAHA
Please excuse the spelling but I am from Texas
fly the airplane first
73 Lee McRight K5MRC
#283
RE: 33cc homelite
I'm getting 7000-7200 rpm with Master Airscrew Classic 18-8 props on mine. Those aren't the most efficient props and you could do even better with better props. I don't know about the exact thrust but the two of them on my Bf 110 twin pull hard!
Jim
Jim
#284
RE: 33cc homelite
I'm only on P. 4 of this thread and finding it interesting. Will continue working my way thru thread with this many pages it is probably there!
Can anyone post the weight of the engines please?
1) with factory ignition, and fins trimmed.
2) has anyone put a CH Ign? and weight with it installed.
#286
TX
RE: 33cc homelite
Mine turns a Bambula 18x8 at 7740rpm on a B&B muffler. Weight with the mag and Hanger Nine mounts is around 4.5lbs. I just converted my 45 to the C-H ignition, forgot to weigh it though. I'll weigh it when my new crankshaft (backordered from Outdoor distributers) gets here.
#287
RE: 33cc homelite
If anybody's interested to see some pictures of how I converted mine, go to: http://www.rcscalebuilder.com/forum/...p?TID=888&PN=4
Jim
Jim
#289
TX
RE: 33cc homelite
The numbers for the 33 are on the stock ignition.
The 45 turned the 18x8 Bambula at 8400rpm with the stock muffler. With a B&B muffler it turned a MA 20x10 at 7320rpm and a Pro Zinger 18x10 at 7710rpm. I crashed the Ultra Stik it was on during the 12th flight due to a battery failure. Straight in, wide open. Bent the crank and the flywheel ( but my carb adapter remained perfectly intact) A couple of weekends ago I got the motor out and straightened the crank ( the best I could) and put another flywheel on it. It ran fine with just a little runout at the prop hub. So I decided to go ahead and make the parts for the C-H conversion and order a new crank ($34.27 from Outdoor Distributers, not too bad) The only prop I've run it on since I converted it is the Pro Zinger 20x8 which it turned at 7830rpm (sorry I don't have any direct comparisons on the same prop). It was shaking a little more than I liked at low speed so I decided to postpone further test until I get the new crank installed.
Those cranks are HARD! I can see why Ralph charges $40 to straighten one. I really don't have the proper equipment in the shop to do the job right.
#290
TN
RE: 33cc homelite
Bought the home depot special 33 cc homelite was very easy to convert mounted in hanger 9 taylor craft in place of pro converter 25 cc homelite was very impressed with the power last sunday on first tries with 18 x8 prop then tried 20 x 10 and the 33 really came alive really belive this engine has a lot left in her to be brought out this was with stock ignition and bennet muffler from a fuji 50 the was trash.
