Magnum 1.80 & Saito 1.50 Gas Conversions?
My Feedback: (111)
Hi,
I have 2 engines (NIB) that I was thinking about converting to gas, and was wondering if it would be worth it? If not, I plan on selling them at a swap meet tomorrow!
What I was interested in is the cost to convert these engines and the reliability once converted? Will they function just as good as they did on glow fuel? I read that I will have to use allot more oil (10%-15%) than a normal gas engine (1%-2%). Also, from what I can gather, the cost of my engine plus the conversion parts, would put me within $100 of just buying an engine designed to run on gas.
Well, should I try and sell these engines and just go out and buy an engine designed to run on gas, or are they worth converting to gas. I would only want to convert them if I could be sure that they would perform as good they they would on glow fuel. I don't want to have to tinker with it for months at the field, or find out that it only puts out a fraction of the power that it would have using glow either.
Any advice you can give me would be greatly appreciated.
Thank You!
Thank You!
RE: Magnum 1.80 & Saito 1.50 Gas Conversions?
These threads could give you some answers to your questions, just read them right through :-
http://www.rcuniverse.com/forum/m_14..._1/key_/tm.htm
http://www.rcuniverse.com/forum/m_12..._1/key_/tm.htm
It can be done....BUT, it's not worth it...[]
One, the oil to gas ratio is way up their because of a bushed rod..about the same as glow.
Two, the added weight of the ignition and battery offsets the benefits..
If you still want to do it, CH Ignitions sells a kit...
My Feedback: (111)
Thanks for the replies guys!
I think I'll try to sell the engines...and get a purpose built gas engine instead.
Mark
Mark
